On 6/3/11 10:05 AM, Chen Xue wrote:
> Hi, there,
> I will install the EPICS Server under vxWorks version 5.4.2 (for
> Motorola MVME 5100). I downloaded the cross-compiler file,
> cross-gcc-2.9.6.tar.gz, for linux from
> http://ics-web.sns.ornl.gov/dht/. Untar it and configured
> WIND_BASE in mkCrossGCC file. When I run ./mkCrossGCC CPU=ppc, I
> got the following error message. Could someone help me?
> Fixing /root/cross-compiler-build-dir/obj-ppc/cpp/gcc/Makefile
> to add CPU
> cd /root/cross-compiler-build-dir/obj-ppc/cpp/gcc ; mv Makefile
> Makefile.orig ;\
> sed 's/^CROSS=/CROSS=-DCPU=PPC603 /' <Makefile.orig >Makefile
> ========= Building gas.config
> mkdir -p /root/cross-compiler-build-dir/obj-ppc/gas
> cd /root/cross-compiler-build-dir/obj-ppc/gas ;\
> /home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure
> --with-cpu=603 --prefix=/home/chen/Cross-Compiler/host/x86-linux
> --target=powerpc-wrs-vxworks --host=i386-redhat-linux
> --with-headers=/home/chen/Cross-Compiler/target/h
> -enable-bfd-assembler
> loading cache ./config.cache
> checking for Cygwin environment... (cached) no
> checking for mingw32 environment... (cached) no
> checking host system type... i386-redhat-linux-gnu
> checking target system type... powerpc-wrs-vxworks
> checking build system type... i386-redhat-linux-gnu
> checking for gcc... (cached) gcc
> checking whether the C compiler (gcc ) works... yes
> checking whether the C compiler (gcc ) is a cross-compiler... no
> checking whether we are using GNU C... (cached) yes
> checking whether gcc accepts -g... (cached) yes
> checking for POSIXized ISC... no
> checking for a BSD compatible install... (cached)
> /usr/bin/install -c
> checking whether build environment is sane... yes
> checking whether make sets ${MAKE}... (cached) yes
> checking for working aclocal... missing
> checking for working autoconf... missing
> checking for working automake... missing
> checking for working autoheader... missing
> checking for working makeinfo... found
> checking for ld used by GCC... (cached) /usr/bin/ld
> checking if the linker (/usr/bin/ld) is GNU ld... (cached) yes
> checking for /usr/bin/ld option to reload object files...
> (cached) -r
> checking for BSD-compatible nm... (cached) /usr/bin/nm -B
> checking whether ln -s works... (cached) yes
> checking how to recognise dependant libraries... (cached) pass_all
> checking for object suffix... (cached) o
> checking for executable suffix... (cached) no
> checking for ranlib... (cached) ranlib
> checking for strip... (cached) strip
> loading cache ./config.cache within ltconfig
> checking whether -lc should be explicitly linked in... (cached) no
> checking for objdir... .libs
> checking for gcc option to produce PIC... -fPIC -DPIC
> checking if gcc PIC flag -fPIC -DPIC works... (cached) yes
> checking if gcc static flag -static works... (cached) yes
> checking if gcc supports -c -o file.o... yes
> checking if gcc supports -fno-rtti -fno-exceptions ... no
> checking whether the linker (/usr/bin/ld) supports shared
> libraries... yes
> checking how to hardcode library paths into programs... immediate
> checking whether stripping libraries is possible... yes
> checking dynamic linker characteristics... GNU/Linux ld.so
> checking command to parse /usr/bin/nm -B output... ok
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... yes
> checking whether to build static libraries... yes
> creating libtool
> checking whether the C compiler (gcc -g -O2 ) works... yes
> checking whether the C compiler (gcc -g -O2 ) is a
> checking for bison... no
> checking for byacc... no
> checking how to run the C preprocessor... gcc -E
> checking for flex... no
> checking for lex... no
> /home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure: 3437:
> flex: not found
> checking for flex... lex
> checking for yywrap in -ll... no
> checking lex output file root...
> /home/chen/Cross-Compiler/host/src/gnu.ppc/gas/configure: 1:
> lex: not found
> configure: error: cannot find output from lex; giving up
> make: *** [gas.config] Error 1
Hi, Chen.
It looks like perhaps you don't have bison and flex installed?
Are the binaries found when you type the following in a Bourne
shell?
$ which bison
$ which flex
On Ubuntu 10.04 LTS, there are packages named bison and flex
that would likely provide what you need.
Lewis
- cross compiler error Chen Xue
RE: cross compiler error Jeff Hill
Re: cross compiler error Chen Xue
<2011>
2025
Mutex at the record level? Steiner, Mathias
<2011>
2025
