1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn connection management with asynPortDriver
To: <[email protected]>
Cc: [email protected]
Date: Mon, 20 Jun 2011 16:18:47 -0500
Hi Euan,
I just did some tests with testAsynPortDriverApp, the test application for asynPortDriver that comes with asyn.  It seems to be working as expected for me.
I changed testAsynPortDriverApp to disable autoconnect in the constructor:
corvette:asyn/testAsynPortDriverApp/src>svn diff
Index: testAsynPortDriver.cpp
--- testAsynPortDriver.cpp      (revision 1768)
+++ testAsynPortDriver.cpp      (working copy)
@@ -238,7 +238,7 @@
                     asynInt32Mask | asynFloat64Mask | asynFloat64ArrayMask | asynDrvUserMask, /* Interface mask */
                     asynInt32Mask | asynFloat64Mask | asynFloat64ArrayMask,  /* Interrupt mask */
                     0, /* asynFlags.  This driver does not block and it is not multi-device, so flag is 0 */
-                    1, /* Autoconnect */
+                    0, /* Autoconnect */
                     0, /* Default priority */
                     0) /* Default stack size*/
I also changed the iocBoot/ioctestAsynPortDriver/st.cmd to load an asyn record on that port.
dbLoadRecords("../../db/asynRecord.db","P=testAPD:,R=asyn1,PORT=testAPD,ADDR=0,OMAX=80,IMAX=80")
When I start the IOC I get a number of error messages like the following:
2011/06/20 15:50:47.810 testAPD:scope1:VoltsPerDiv devAsynFloat64:process error queuing request port testAPD not connected
2011/06/20 15:50:47.811 testAPD:scope1:Run_RBV devAsynInt32 queueRequest port testAPD not connected
2011/06/20 15:50:47.811 testAPD:scope1:Run devAsynInt32::processCommon, error queuing request port testAPD not connected
These errors are expected, because these records have PINI=YES, but the port is not connected.
When I look at the medm screen for the asyn record it shows .AUCT=“noAutoConnect” (in yellow) and .CNCT readback widget=”Disconnected” (in red).
If I toggle the scope1:Run PV between Stop and Run I get the following errors on the IOC:
2011/06/20 15:54:26.108 testAPD:scope1:Run devAsynInt32::processCommon, error queuing request port testAPD not connected
2011/06/20 15:54:26.481 testAPD:scope1:Run devAsynInt32::processCommon, error queuing request port testAPD not connected
Again, those are expected, because the asyn port is disconnected.
Now, I use the medm screen for the asyn record to change the CNCT field from “Disconnect” to “Connect”.  The readback widget changes from “Disconnected” in red to “Connected” in green.
When I then toggle the scope1:Run PV the simulated scope display begins to update normally.
Thus, I don’t see the problems you are describing.  I am running the SVN version of asyn (soon to be R4-17), while you are running 4-16.  But there have not been any changes in connection management since 4-16.
In your original message you said:
> If I create the port driver class with the autoconnect flag set to true I can use the asynRecord CNCT field to connect or disconnect a device from the port.
Actually, the CNCT field is normally used when the autoconnect flag is set to false; it is not needed if the autoconnect flag is set to true.
In your second message you said:
> If the asynPortDriver class is instantiated with autoConnect disabled then the PCNCT field
> of the asynRecord shows 'Connect' which I think means the port is connected.
No, that is not correct, and perhaps this is the source of the confusion.  Here you refer to the PCNCT field, while in your original message you were referring to the CNCT field.  They do two very different things.
The PCNCT field controls the connection of the pasynUser structure to the asyn port.  This invokes a call to pasynManager->connectDevice().  The CNCT field controls the connection of the device to the asyn port.  This invokes a call to pasynCommon->connect(). asynManager will normally not let you queue a request unless the device is connected to the port.  The exception is that you can queue connection requests, which is what the .CNCT field in the asyn record does.
This is what I see when the port is disconnected:
epics> asynReport 4
testAPD multiDevice:No canBlock:No autoConnect:No
    enabled:Yes connected:No numberConnects 1
    nDevices 0 nQueued 0 blocked:No
    asynManagerLock:No synchronousLock:No
    exceptionActive:No exceptionUsers 1 exceptionNotifys 0
    interfaceList
When I then use medm to set .CNCT=Connect I get the following:
epics> asynReport 4
    enabled:Yes connected:Yes numberConnects 2
    interfaceList
Let me know if you still have questions or problems.
Cheers,
-----Original Message-----
Sent: Thursday, June 09, 2011 6:28 PM
To: Mark Rivers
Subject: Re: asyn connection management with asynPortDriver
Hi Mark,
A bit more information about why I am confused. If the asynPortDriver class is instantiated with autoConnect disabled then the PCNCT field
of the asynRecord shows 'Connect' which I think means the port is connected. However asynReport in the IOC says the port isn't connected.
There doesn't seem to be a mechanism for connecting the port itself except via autoConnect, although I think that the ::connect method called with addr=-1 is what the documentation implies.
e.g.
epics> asynReport 4
drx1 multiDevice:Yes canBlock:Yes autoConnect:No
    enabled:Yes connected:No numberConnects 0
epics> dbpr as:t:as01:drx:s1:asynRecord 4
ACKS: NO_ALARM      ACKT: YES           ACMD: None          ADDR: 0
AINP:               AOUT:               AQR: 0              ASG:
ASP: (nil)          AUCT: noAutoConnect BAUD: Unknown       BINP: 0
BKPT: 00            BOUT: 0             CNCT: Disconnect    DBIT: Unknown
DESC:               DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DPVT: 0xaa61c40     DRVINFO:            DSET: 0xb7740988
DTYP: asynRecordDevice                  ENBL: Enable        EOMR: None
ERRS: 0xaa61f20     EVNT: 0             F64INP: 0           F64IV: 1
F64OUT: 0           FCTL: Unknown       FLNK:CONSTANT 0     GPIBIV: 0
I32INP: 0           I32IV: 1            I32OUT: 0           IEOS:
IFACE: asynOctet    IFMT: ASCII         IMAX: 80            IPTR: 0xaa61e70
LCNT: 0             LSET: 0xb6c75078    MCTL: Unknown
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00                   MLOK: 28 1c a6 0a
NAME: as:t:as01:drx:s1:asynRecord       NAWT: 0             NORD: 0
NOWT: 80            NRRD: 0             NSEV: NO_ALARM      NSTA: NO_ALARM
OCTETIV: 1          OEOS:               OFMT: ASCII         OMAX: 80
OPTIONIV: 0         OPTR: 0xaa61e18     PACT: 0             PCNCT: Connect
PHAS: 0             PINI: NO            PORT: drx1          PPN: (nil)
PPNR: (nil)         PRIO: LOW           PROC: 0             PRTY: Unknown
PUTF: 0             RDES: 0x9dc5570     REASON: 0           RPRO: 0
RSET: 0xb7740940    SBIT: Unknown       SCAN: Passive       SDIS:CONSTANT
SEVR: NO_ALARM      SOCK:               SPR: 0              SPVT: (nil)
STAT: NO_ALARM      TB0: On             TB1: Off            TB2: Off
TB3: Off            TB4: Off            TFIL: Unknown       TIB0: Off
TIB1: Off           TIB2: Off           TIME: <undefined>   TINP:
TIOM: 0             TMOD: Write/Read    TMOT: 1             TMSK: 1
TPRO: 0             TSE: 0              TSEL:CONSTANT       TSIZ: 80
UCMD: None          UDF: 0              UI32INP: 0          UI32IV: 1
UI32MASK: 4294967295                    UI32OUT: 0          VAL:
cheers,
Euan.
On 10/06/2011, at 2:16 AM, Mark Rivers wrote:
> Hi Euan,
> I am away from the lab, but I will look into this and get you an answer when I return on June 20.  It seems like the asyn record should do what you want, but maybe something is wrong.
> Meanwhile perhaps Eric Norum can help :-)
> Mark
> ________________________________
> From: [email protected] on behalf of [email protected]
> Sent: Wed 6/8/2011 8:25 PM
> To: [email protected]
> Subject: asyn connection management with asynPortDriver
> Hi,
> I would like to use the connection management features of asyn with a driver based on the asynPortDriver class. If I create the port driver class with the autoconnect flag set to true I can use the asynRecord CNCT field to connect or disconnect a device from the port. If autoconnect is set to false, then when the IOC starts up, the following messages appear:
> iocRun: All initialization complete
> epics> 2011/06/09 10:51:51.625 as:t:as01:drx:s1:asynRecord: queueRequest failed for special.
> 2011/06/09 10:51:51.625 as:t:as01:drx:s1:asynRecord: port drx1 not connected
> If I try and use the CNCT field if the asyn record to connect a device then a similar message is produced:
> epics> 2011/06/09 11:00:29.564 as:t:as01:drx:s1:asynRecord: exception 2
> 2011/06/09 11:00:39.172 as:t:as01:drx:s1:asynRecord: queueRequest failed for special.
> 2011/06/09 11:00:39.172 as:t:as01:drx:s1:asynRecord: port drx1 not connected
> As I understand the setup, the asynPortDriver constructor will connect the port and the class methods connect() and disconnect() will connect  devices to the port. I have derived these methods in my class so that I can manage connections but without autoconnect to make the first connection these methods are not called. So even though the port is connected, without autoconnect I can't connect any devices to the port. I guess there is some setup I haven't performed. I would like advice as to how to manage the connections. I am using asyn 4.16 with EPICS 3.14.12.
> cheers,
> Euan.
asyn connection management with asynPortDriver Euan.Troup
RE: asyn connection management with asynPortDriver Mark Rivers
Re: asyn connection management with asynPortDriver Euan.Troup
Prev: RE: radiation damage to electronics inside accelerator tunnel? Rarback, Harvey M.
Next: Areadetector: driver for VDS Vosskuhler gigE camera? Paul Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn connection management with asynPortDriver Euan.Troup
Next: APS Website issues Andrew Johnson
