1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Fuzzy controller in EPICS
To: "Florian Feldbauer" <[email protected]>, "EPICS tech talk" <[email protected]>
Cc: Jörn Becker <[email protected]>
Date: Tue, 21 Jun 2011 06:48:01 -0500
Hi Florian,
The EPICS EPID record may do what you want.  You would read back the temperature sensors inside the detector (perhaps using a calc record to average them and discard outliers) and control the chillers.  We use EPID for many temperature control applications, with extra logic in calc records to limit voltage, current, and power, etc.  If you need to control more than 1 chiller you can use multiple EPID records, or fan the output of a single one.
http://cars9.uchicago.edu/software/epics/epidRecord.html
From: [email protected] on behalf of Florian Feldbauer
Sent: Tue 6/21/2011 6:32 AM
To: EPICS tech talk
Cc: Jörn Becker
Subject: Fuzzy controller in EPICS
Dear all,
we are developing a prototype for the EMC of the PANDA detector.
The whole prototype has to be cooled down to -25 degree Celsius.
We have two chillers which are controlled via serial line and several
temperature sensors
inside our detector.
Only the temperature of the internal reservoir of the chillers can be
set. (Not the used head/cooling power).
So we need a controlling routine which uses the data from our
temperature sensors and regulating our chillers.
We thought about using a fuzzy controller.
Does anyone has experience with this, or already implemented something
like this in EPICS?
Best regards,
Florian
| Florian Feldbauer                 |
| Ph.D. student                     |
| Institut für Experimentalphysik I |
| Ruhr-Universität Bochum           |
| Universitätsstr. 150              |
| D-44780 Bochum                    |
| Office: NB 2/173                  |
| Phone:  (+49)234 / 32-23538       |
| Fax:    (+49)234 / 32-14170       |
| Web:    http://www.ep1.rub.de <http://www.ep1.rub.de/>      |
Fuzzy controller in EPICS Florian Feldbauer
Prev: Fuzzy controller in EPICS Florian Feldbauer
Next: Re: radiation damage to electronics inside accelerator tunnel? Mohan Ramanathan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: fft Michael Davidsaver
