1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Areadetector: driver for VDS Vosskuhler gigE camera?
To: Paul Martin <[email protected]>
Date: Tue, 21 Jun 2011 09:24:38 -0500
Hi Paul,
We are using that detector here at APS.  I have written an areadetector driver for it which is being tested now.  If you are interested, I can send you what I have.
Jeff
On 6/21/2011 1:47 AM, Paul Martin wrote:
Has anyone developed or is currently developing an areadetector GigE Vision driver for the VDS 11000XR camera, also known as CCD011000XR or Scint-X DXI-11000
It uses an Ethernet adapter based on Pleora Technologies implementation of GigE Vision, used on many VDS Vosskuhler cameras (and maybe others), if that helps?
Many Thanks
Paul Martin
Australian Synchrotron
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Jeffrey Gebhardt
Beamline Controls and Data Acquisition
APS Engineering Support Division
630-252-5026
Areadetector: driver for VDS Vosskuhler gigE camera? Paul Martin
Prev: Re: radiation damage to electronics inside accelerator tunnel? Mohan Ramanathan
Next: Re: long strings in edm Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Areadetector: driver for VDS Vosskuhler gigE camera? tom.cobb
Next: Fuzzy controller in EPICS Florian Feldbauer
