1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer news: latest snapshot
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Fri, 24 Jun 2011 23:05:10 +0200
Hi Lewis
thank you for testing on Mac OS.
Am Freitag, 24. Juni 2011, um 16:49:00 schrieben Sie:
> On 6/24/11 8:51 AM, Benjamin Franksen wrote:
> > On Friday, June 24, 2011, Benjamin Franksen wrote:
> >> the latest snapshot I uploaded today fixes the remaining problems when
> >> running the tests.
> > I made some last-minute stupid errors when uploading. If you have
> > downloaded the snapshot before this message was sent, then please
> > download again. Sorry for any inconvenience this may have caused.
> It builds without any warnings on my system.
Good.
> The tests didn't hang up, but it looks like not all of them
> passed. (?)  Here's the output:
> $ make -s runtests
> test.t .. 1/15
> #   Failed test at test.t line 47.
> test.t .. 15/15 # Looks like you failed 1 test of 15.
> test.t .. Dubious, test returned 1 (wstat 256, 0x100)
> Failed 1/15 subtests
> Test Summary Report
> test.t (Wstat: 256 Tests: 15 Failed: 1)
>   Failed test:  2
>   Non-zero exit status: 1
> Files=1, Tests=15,  7 wallclock secs ( 0.02 usr  0.00 sys +
> 5.03 cusr  1.25 csys =  6.30 CPU)
> Result: FAIL
> Failed 1/1 test programs. 1/15 subtests failed.
This seems to be the only test that failed.
The tests in this group check that the (SNL+C) compilers reject certain
constructs; I have made these tests more strict by counting how often the word
'error' appears in the output. Depending on the C compiler this number varies,
so I have to adapt the range of permissible occurrences for every new compiler
tested. Could you remove the comment marker from line 43 of
test/compiler/test.plt, repeat 'make runtests' inside test/compiler, and send
me the output?
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Sequencer news: latest snapshot J. Lewis Muir
Sequencer news: latest snapshot Benjamin Franksen
Re: Sequencer news: latest snapshot Benjamin Franksen
Prev: Mantis 339 "enum string tbl cache read ASYNC IO postponed fixed" bug still around? Tom Cumming
Next: Re: Sequencer news: latest snapshot J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer news: latest snapshot J. Lewis Muir
