1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer news: latest snapshot
To: [email protected]
Date: Sat, 25 Jun 2011 23:27:19 -0500
Hi Ben,
On Saturday, June 25, 2011 20:00:34 Benjamin Franksen wrote:
> This is correct; the problem is that the perl script thinks the test should
> succeed, not fail, since the EPICS_HOST_ARCH does not match against the
> string '64'. So, I rather have to adapt the expectation and refine the
> heuristic that tries to determine 64-bit-ness of the host arch. What is
> the value of EPICS_HOST_ARCH for your system?
You're going to have "fun" with this test on Macs, which can be configured to
actually execute the C compiler up to 4 times when you run gcc once, depending
on the setting for ARCH_CLASS which sends a -arch option to gcc.  This is how
you get it to generate Fat Binaries, which contain code for more than one
processor architecture.  The EPICS build system configuration lets individual
sites decide what architectures they want to include in their binaries on
darwin.
If you look at the comments in the file
    base/configure/os/CONFIG_SITE.Common.darwin-ppcx86
you'll get some idea of the possible combinations (the CONFIG_SITE files for
the other darwin target-architectures contain a reduced list of possibilities,
but in practice any target-arch can be configured to build for any combination
of binaries).  This means you shouldn't try to rely on EPICS_HOST_ARCH
containing the string "64" when you're building for a 64-bit CPU, and even if
it does it isn't necessarily going to be /only/ building for a 64-bit CPU.
I think trying to parse the output from the compiler is not worth doing, it's
too variable given the wide variety of architectures EPICS can be built for.
- Andrew
Re: Sequencer news: latest snapshot Benjamin Franksen
Re: Sequencer news: latest snapshot J. Lewis Muir
Prev: Re: Sequencer news: latest snapshot Benjamin Franksen
Next: Re: Sequencer news: latest snapshot Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
