1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Newport XPS and Motor record
To: "John Dobbins" <[email protected]>
Cc: [email protected]
Date: Mon, 27 Jun 2011 17:58:18 -0500
Hi John,
Yes, you are reading that correctly.
The first time the command is sent it times out waiting for a response.
That timeout is normal, because the XPS does not send a response on that
socket until the move completes, and the driver does not wait for that,
it uses a short timeout.
The second time it sends the command it gets a -1 error response.  This
error translates as:
Error -1 : Busy socket : previous command not yet finished
The third time it sends the command it get a -22 error response, which
translates as:
Error -22 : Not allowed action
Something is not right!
Here is what I see on my XPS IOC when I turn on the same asynTrace:
ioc13bmd> 2011/06/27 17:48:24.701 164.54.160.83:5001 TCP write 44
GroupMoveAbsolute (GROUP1.POSITIONER,2.1269)
2011/06/27 17:48:24.801 SendAndReceive, sent: 'GroupMoveAbsolute
(GROUP1.POSITIONER,2.1269)'
2011/06/27 17:48:24.801 SendAndReceive, timeout on read
I only see a single GroupMoveAbsolute command sent, not 3.
Do you have a non-zero number of retries (.RTRY) set on the motor?  I
wonder if those could be retry attempts, though that does not make
sense, since a retry should not happen until the move completes.
Can you send the output of
dbpr "mymotor",10
-----Original Message-----
Sent: Monday, June 27, 2011 3:40 PM
To: Mark Rivers
Subject: Re: Newport XPS and Motor record
Mark,
Thanks for the specific suggestions.
The asyTrace output seems to show the move command is sent three times!?
Am I reading this right?
John
epics> 2011/06/27 16:26:49.689 erpxps01:5001 TCP write 52
GroupMoveAbsolute (GROUP2.POSITIONER,11.20009791225)
2011/06/27 16:26:49.790 SendAndReceive, sent: 'GroupMoveAbsolute
(GROUP2.POSITIONER,11.20009791225)'
2011/06/27 16:26:49.790 SendAndReceive, timeout on read
2011/06/27 16:26:49.791 erpxps01:5001 TCP write 52
2011/06/27 16:26:49.791 erpxps01:5001 TCP read 64
-1,GroupMoveAbsolute (GROUP2.POSITIONER,11.20009791225),EndOfAPI
2011/06/27 16:26:49.791 SendAndReceive, sent: 'GroupMoveAbsolute
2011/06/27 16:26:49.791 SendAndReceive, read: '-1,GroupMoveAbsolute
(GROUP2.POSITIONER,11.20009791225),EndOfAPI'
2011/06/27 16:26:49.792 erpxps01:5001 TCP read 65
-22,GroupMoveAbsolute (GROUP2.POSITIONER,11.20009791225),EndOfAPI
2011/06/27 16:26:49.792 SendAndReceive, sent: 'GroupMoveAbsolute
2011/06/27 16:26:49.792 SendAndReceive, read: '-22,GroupMoveAbsolute
2011/06/27 16:26:49.792 SendAndReceive unexpected response
=-22,GroupMoveAbsolute (GROUP2.POSITIONER,11.20009791225),EndOfAPI
On 6/27/2011 2:50 PM, Mark Rivers wrote:
> Hi John,
>> If I look in the XPS web interface I don't see any errors reported
>> there. Should I expect to see them there?
> No, you would not see them there.  You can use the terminal interface
in
> the Web page to translate error numbers into messages, but you won't
see
> messages as errors occur.
> If the motor is moving normally, but is reporting that error, then I
> wonder if perhaps it is being told to move a second time while it is
> already moving, for example?
> You can do
> asynReport
> to see the names of all of the asyn IP port drivers connected to this
> XPS.  There will be several.  One is used for status on all axes, and
> there is 1 per axis for issuing "move" commands.  You can enable trace
> debugging on these ports with
> asynSetTraceIOMask "port",0,2
> asynSetTraceMask "port",0,9
> That sets asynTraceIOEscape (to see ASCII messages with escape
> sequences) and asynTraceIODriver, to see messages from the asyn IP
> driver.
> With that level of debugging you should be able to see what commands
are
> being sent to the XPS, and which ones are working, and which are
> resulting in the error you see.
> Send the output of "dbpr myMotor 10" (which will print all the motor
> record fields) and the contents of the stage definition file for those
> motors, so we can compare maximum velocity, acceleration, limits, etc.
> Mark
> From: [email protected]
> [mailto:[email protected]] On Behalf Of John Dobbins
> Sent: Monday, June 27, 2011 1:29 PM
> To: [email protected]
> All,
> Thanks for the various replies.
> The stages actually move normally. And report statuses that would be
> expected, "Ready from Homing", "Reading from Moving", ...
> Also I have two different stage types connected and both types produce
> this error.
> The XPS configuration was generated by the XPS using that option as
> available in the web interface. Limits, velocities, ... appear to be
set
> correctly. So I can't tell what the XPS is complaining about.
> John
> On 6/27/2011 11:57 AM, John Hammonds wrote:
>> I once had a problem that the configured velocity (in the motor
> record)
>> was not allowed by the XPS.  It returned the same error code.  This
> was
>> a manually configured motor.   We had to play around a bit to get the
>> XPS configuration correct.
>> John
>> On 6/27/2011 10:52 AM, Pete Jemian wrote:
>>> John:
>>> What is your configuration in the XPS controller?
>>> Can that have some influence?
>>> Pete
>>> On 06/27/2011 09:51 AM, [email protected] wrote:
>>>> Hi,
>>>> It could also be that the XPS axis is in the wrong 'state'. I think
>>>> it needs to be in 'ready state' (states 10 to 13) to receive move
>>>> commands.
>>>> I updated the XPS driver recently. So in the next release of the
>>>> motor support module the driver should indicate if there is a
> problem
>>>> (via the motor record MSTA field). So if the axis is in a state
> which
>>>> means you can't move it then you will be notified by the record
> going
>>>> into alarm state.
>>>> Cheers,
>>>> Matthew
>>>>> From: [email protected] [mailto:tech-talk-
>>>>> [email protected]] On Behalf Of Mark Rivers
>>>>> Sent: 27 June 2011 15:17
>>>>> To: John Dobbins; EPICS Tech-Talk
>>>>> Hi John,
>>>>> If you translate that error code, -22, using ErrorStringGet in the
> XPS
>>>>> Web terminal interface you will get:
>>>>> 0,Error -22 : Not allowed action
>>>>> So there is something illegal about the request you are making.
Is
> it
>>>>> possible that you are exceeding a soft limit, etc.?
>>>>> Mark
>>>>> Sent: Monday, June 27, 2011 8:38 AM
>>>>> To: EPICS Tech-Talk
>>>>> Subject: Newport XPS and Motor record
>>>>> All,
>>>>> I am using Motor Record R6-4-4 , EPICS R3.14.9, ASYN 4-9 with a
> Newport
>>>>> XPS controller.
>>>>> When I send a new position to an actuator I get a messages in the
> IOC
>>>>> like this:
>>>>> epics>    2011/06/24 12:35:35.552 SendAndReceive unexpected
response
>>>>> =-22,GroupMoveAbsolute (GROUP2.POSITIONER,12.00003072008),EndOfAPI
>>>>> otherwise everything seems to be working, i.e. motor responds
> properly.
>>>>> Does someone know what this means? The XPS set-up portion of my
> st.cmd
>>>>> script is below.
>>>>> Regards and Thanks,
>>>>> John Dobbins
>>>>> Cornell University
>>>>> The XPS set-up portion of my st.cmd script:
>>>>> # cards (total controllers)
>>>>> XPSSetup(1)
>>>>> # card, IP, PORT, number of axes, active poll period (ms), idle
> poll
>>>>> period (ms)
>>>>> XPSConfig(0, "erpxps01", 5001, 3, 10, 500)
>>>>> # asyn port, driver name, controller index, max. axes)
>>>>> drvAsynMotorConfigure("XPS1", "motorXPS", 0, 3)
>>>>> # card,  axis, groupName.positionerName, stepsPerUserUnit
>>>>> # PR50CC rotational stage
>>>>> XPSConfigAxis(0,0,"GROUP1.POSITIONER",100)
>>>>> # CMA-12CCCL linear stage
>>>>> XPSConfigAxis(0,1,"GROUP2.POSITIONER",20480)
>>>>> XPSConfigAxis(0,2,"GROUP3.POSITIONER",20480)
Re: Newport XPS and Motor record John Dobbins
RE: Newport XPS and Motor record John Dobbins
RE: Newport XPS and Motor record Mark Rivers
RE: Newport XPS and Motor record matthew.pearson
Re: Newport XPS and Motor record Pete Jemian
Re: Newport XPS and Motor record John Hammonds
Prev: Re: Sequencer news: latest snapshot J. Lewis Muir
Next: Record Alarm/ AsynPortDriver Rime Ateia
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Newport XPS and Motor record John Dobbins
Next: Re: Newport XPS and Motor record John Dobbins
