1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer news: latest snapshot
To: <[email protected]>
Date: Tue, 28 Jun 2011 13:18:16 +0200
Ok, my current solution is two test scripts, one for 64 bit and the other
one for 32 bit systems. I factored out the common stuff into a perl module.
The Makefile looks like this:
ifeq '$(findstring 64,$(ARCH_CLASS))' ''
TESTSCRIPTS_HOST += make_test.t
TESTSCRIPTS_CROSS += make_test.t
else
TESTSCRIPTS_HOST += make64_test.t
TESTSCRIPTS_CROSS += make64_test.t
endif
Works fine on 32 bit linux and windows; I will test this on 64 bit linux and
if that works, too, I think the sequencer is finally ripe for a 2.1.0
release candidate.
Cheers
Ben
On Tuesday, June 28, 2011, Benjamin Franksen wrote:
> On Monday, June 27, 2011, J. Lewis Muir wrote:
> > On 6/27/11 4:09 PM, Benjamin Franksen wrote:
> > > Yes, that was the idea. However, with the current build rules for
> > > TESTPRODUCTs I see no way to communicate the distinction from the
> > > Makefile to the test script. By parsing the last part of the cwd I
> > > could find out the T_A, and if we adopted the above proposal, I could
> > > match it with '64' inside the test script...
> > I'm not understanding.  Say you could know that the fat binary
> > included the i386 and x86_64 target architectures (in the make
> > file or in the test script).  How does that help you?  Are you
> > saying it would help because you'd be able to predict how many
> > errors you should get?
> No. If I knew it included x86_64 (and other, maybe 32 bit archs) then I
> also knew that the SNL code should not contain 'assign' declarations to
> 'long' or 'unsigned long', so I knew that the generated C code should be
> such that the C-preprocessor/compiler should fail compilation. This is
> what I want to test.
> I am fairly certain that the snc code in question is correct and will
> always produce an error, so it may seem that this test is not very
> important. But I may not be the last person to work on this code, and
> someone else might (erroneously) think they could simplify it. (This
> happens to me all the time...) A regression test makes sure such a
> mistake becomes obvious pretty fast.
> Cheers
> Ben
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv.
> Vorsitzende Dr. Beatrix Vierkorn-Rudolph Geschäftsführer: Prof. Dr. Anke
> Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
D-14109 Berlin
Sequencer news: latest snapshot Benjamin Franksen
Re: Sequencer news: latest snapshot J. Lewis Muir
Re: Sequencer news: latest snapshot Benjamin Franksen
Prev: RE: Record Alarm/ AsynPortDriver Mark Rivers
Next: Re: Sequencer news: latest snapshot Pelaia II, Tom
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer news: latest snapshot Benjamin Franksen
