1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: EPICS Soft IOC hardware switch
To: [email protected]
Date: Thu, 30 Jun 2011 11:17:10 -0500
Hello.
I am looking for an EPICS compatible hardware switch that  has two enumerated
PV values. For example when the switch is pressed its  PV value is 1 and when
the switch is released its PV value is 0. I need to run that on a software IOC
Linux box. I have Keythley multimeter and I could use one of its channels for
that purpose but maybe someone else has already done something similar or
there is an existing hardware solution that can run on soft IOC ?
Thank you.
Miroslav Mihaylov
University of Illinois at Chicago
Department of Physics
2336 SES
845 W. Taylor St. M/C 273
Chicago, IL 60607
312 355 0225
Re: EPICS Soft IOC hardware switch Eric Norum
Prev: RE: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Gurd Pamela EXT
Next: Re: Does EPICS Base support multi-thread on vxWorks 6.3? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Utzel Nadine
Next: Re: EPICS Soft IOC hardware switch Eric Norum
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
