1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Creating a Simple EPICS Sequencer Program
To: Jay Steele <[email protected]>, [email protected]
Date: Thu, 7 Jul 2011 10:35:25 -0400
Thank you for you're help, Jay.  I have now successfully built and ran the example program called "sncExample.stt" that is created when I run "makeBaseApp.pl -t example example" followed by "makeBaseApp.pl -i -t example example".  When you say I can simply create my own EPICS application by putting the .st file in the SRCS list in the application's Makefile, exactly what list are you referring to? Are you referring to this Makefile: "<top>/exampleApp/src/Makefile"?  In that Makefile, there is a section that builds sncExample as a component of example and as a standalone application.  Is that where I add my own .st program?
Brad Pietrzak
Indiana University Center for the Exploration of Energy and Matter
On Thu, Jun 16, 2011 at 2:22 PM, Jay Steele <[email protected]> wrote:
Hi Bradley,
   I just went through the process of coming up to speed on State Notation Language myself with EPICS for a robot control application and it is very useful. After you experiment around a little with the example IOC template (per Eric's suggestion below), and then build your own EPICS application, you can simply put the .st file in the application's src directory and add the .st file to the SRCS list in the application makefile. Also, for non-VxWorks OS's such as Linux, add a registrar(stnameRegistrar) statement to your appCommonInclude.dbd file. Then start the SNL task by calling the seq function from your application's startup script after iocInit. See the online document "State Notation Language and Sequencer Users Guide" for a well-written introduction.
   I recommend drawing up your state diagram first if it is complicated.
Cheers,
Jay Steele
Xradia Corporation
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Eric Norum
Sent: Thursday, June 16, 2011 11:08 AM
To: Bradley Pietrzak
Cc: [email protected]
The example IOC template includes a sequencer program.  I suggest that you use that as a starting point:
makeBaseApp -t example example
makeBaseApp -t example -i example
then edit configure/RELEASE and set SNCEQ
then 'make' and you should have a runnable IOC with an operational sequencer.
On Jun 16, 2011, at 10:47 AM, Bradley Pietrzak wrote:
> Hello,
> I am a student working at the Indiana Univeristy Center for the Exploration of Energy and Matter.  Recently, a collegue and I have been tasked with using the EPICS sequencer to cycle some magnets.  However, neither of us are at all familiar with using state notation language.  Our setup is this: we have a computer with a virtual machine on it that contains EPICS and the sequencer.  We do all of our work from a different machine that runs Red Hat Linux.  Using that machine, we ssh into the EPICS virtual machine.  While I have read a couple State Notation Language tutorials, I am still unclear on some key concepts.  What I would most like to know is how to start from nothing and make a program that does nothing more than print the text "Hello World".  I think what confuses us most is how to go from a file named "HelloWorld.st" to something we can actually execute.  At least for now, lets assume that all of the relevant compilers are successfully installed on the EPICS virtua!
 l machine.
> Sincerely,
> Brad Pietrzak
Eric Norum
[email protected]
 The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed.  Any use of this email for any other purpose is prohibited.  If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
RE: Creating a Simple EPICS Sequencer Program Jay Steele
Creating a Simple EPICS Sequencer Program Bradley Pietrzak
Re: Creating a Simple EPICS Sequencer Program Eric Norum
Prev: RE: AreaDetector CBF file writing plugin Mark Rivers
Next: RE: AreaDetector CBF file writing plugin emma.shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Creating a Simple EPICS Sequencer Program Jay Steele
Next: RE: Creating a Simple EPICS Sequencer Program Jay Steele
