1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streamdevice + asyn stuck
To: "Zhang, Dehong" <[email protected]>
Date: Wed, 13 Jul 2011 09:47:29 +0200
Hello Dehong,
Zhang, Dehong wrote:
Hi Dirk and Mark,
Thank you very much for helping!
I tried to change the SCAN to "10 second", it did not help.  I also tried the
epicsThreadShowAll command as Dirk suggested, it shows a few timerQueue
threads, all "OK"
Some time ago I had the problem that I crashed the timerQueue thread in a timeout callback and thus never completed record processing. However, this seems to be a different issue because you don't see crashed threads.
From what I can see from the source code, I believe that we somehow
lose callbacks from asyn, that breaks the evalcommand() chain and we
never get to finishProtocol().
Yes. That seems to be the case. At several places, StreamDevice gives control to asyn or to EPICS base and relies on callbacks. If the callbacks don't come, StreamDevice is lost.
I have to check if I did anything wrong there. Basically I give control to asynDriver using queueRequest() and expect a callback either to handleRequest() or handleTimeout(). From there I call the individual event handlers. So maybe either my queueRequest() setup is wrong or my handlers are buggy or asynDriver never calls back. (all code in AsynDriverInterface.cc)
Later I give control to EPICS base via callbackRequest() to finish processing the record. But I don't think that there is something wrong. (code in StreamEpics.cc)
I will try to add some diagnostics to see what a record is currently waiting for. But that may take a while.
Another possibility is the mutex.  If it is not released properly, the
Stream::process() method will be stuck waiting.
The mutex is automatically released (via destructor) when the function that contains the lock returns. Thus the only way to keep the lock is to get stuck in a function while holding the lock. But because I don't think I have unbounded loops in any function, that can only happen when a thread crashes or a function I call does not return. I don't think that happens.
Please switch on debugging (var streamDebug,1). Better remove or disable all other StreamDevice records or the output will be overwhelming. What are the last messages you get from a record before is gets stuck?
Dirk
Sent: Tuesday, July 12, 2011 12:21 AM
To: Zhang, Dehong
Cc: [email protected]; [email protected]
Hello Dehong,
Do you have a hung up timerQueue thread? Try epicsThreadShowAll.
Dirk
Hi Dirk, Mark and fellow EPICSers,
Sorry to bother you with this.  I tried to chase the source code and search the tech-talk,
but could not find much hints.
We use base 3.14.9, streamdevice 2.4 and asyn 4.10, have been experiencing this stuck
problem for some time.  The symptom is that randomly, a mbbi/ai/bi... (input) record would
stop updating and no longer does FLNK, with no error/warning messages printed in the log
file.  And dbpr *** 3 would show that:
LCNT=11
SEVR=INVALID
STAT=SCAN
And manually writing to the PROC field also does nothing.
It seems like the record is stuck waiting for a callback from streamdevice (and asyn), and
the EPICS framework just ignores any "PROC" requests.
In the protocol file we do have the timeouts etc:
locktimeout  = 5000;
terminator   = CR;
replytimeout = 1000;
readtimeout  = 1000;
extrainput   = Ignore;
While chasing the problem, I noticed that "asynReport 10 ***" would show:
multiDevice:No canBlock:Yes autoConnect:Yes
    enabled:Yes connected:Yes numberConnects 1
For some the numberConnects can be 2.
Is this "canBlock:Yes" related to my problem?  Should the numberConnects be <=1?
We use one port to talk to one device.
Rebooting the IOC does fix the problems, but then they would come back, randomly.
Please advise.  Thank you very much.
Best regards,
Dehong
RE: streamdevice + asyn stuck Zhang, Dehong
Re: streamdevice + asyn stuck Dirk Zimoch
Prev: CSS errors: cannot excute Ma Xiaoyuan
Next: RE: CSS errors: cannot excute Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: streamdevice + asyn stuck Mark Rivers
Next: RE: streamdevice + asyn stuck Zhang, Dehong
