1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Delay problem in ca_array_put() command
Date: Mon, 18 Jul 2011 07:45:55 +0000
Hi everybody,
I 'm working on a IOC or Portable CA Server capable of managing other IOC in order to sequence them, for instance. Typically this IOC controls multiple motors, each represented by an IOC.
I don’t know which type of implementation (Portable CA Server or IOC) is the most efficient. In this case, I started implementing an IOC. is it a good choice ?
More particularly, I’ve a problem with the part of this IOC acting as the client of the others IOC it controls. This client monitors  a few PV of the motor’s IOC and all seems ok. It’s a multi-threaded client. I’ve created my CA context with :
                                ca_context_create(ca_enable_preemptive_callback);
And to be notified of change events, I’ve created a thread to launch :
ca_pend_event (0.0);
The problem occurs when I want to change a PV value. All seems ok but the pv is only really modified 30 seconds to 1 min after the call to ca_array_put (I have tested this in localhost) . To change a value, I proceed in the following manner for a double :
                               ca_array_put(DBR_DOUBLE, 1, channel, &val);
status=ca_pend_io(put_timeout);
Is this a normal behaviour? If not, how can this issue be solved?
Thanks in advance,
Best regards,
Pierre PERRIER
Stagiaire - MCO LIL
Sopra group.
Parc Innolin
9 rue du Golf 33700 Merignac
Phone : +33 (0)5 56 12 79 59
[email protected] - www.sopragroup.com
Ce message peut contenir des informations confidentielles dont la divulgation est à ce titre rigoureusement interdite en l'absence d'autorisation explicite de l'émetteur. Dans l'hypothèse où vous auriez reçu par erreur ce message, merci de le renvoyer à l’émetteur et de détruire toute copie.
P Pensez à l’environnement avant d’imprimer.
RE: Delay problem in ca_array_put() command Jeff Hill
Prev: RE: streamdevice + asyn stuck Zhang, Dehong
Next: EPICS OSI and events michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Announce: sequencer release 2.1.0 Benjamin Franksen
Next: RE: Delay problem in ca_array_put() command Jeff Hill
