1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Does EPICS Base support multi-thread on vxWorks 6.3?
Cc: [email protected]
Date: Thu, 21 Jul 2011 17:07:55 +0800
Finally, I'm able to build my own vxTestHarness.munch. I put it onto my vxWorks system, load it, and run the command epicsThreadPrivateTest, all 5 tests passed.
Now I have no idea what has caused our problem :(
Actually we DO use EPICS build system, to build the static libraries (.a files on vxWorks). And then we link all the static libraries that we need into a single dynamic library (.o file on vxWorks). I'm not sure if there's munching stuff happening during the linking process. Could that be the issue?
Lorna Zhang
To: [email protected]
Cc: "Jeff Hill" <[email protected]>, [email protected]
Date: 07/01/2011 02:17 AM
Hi Lorna,
On 2011-06-30 [email protected] wrote:
> We are not using the EPICS build system.
Do you use C++ in any of the other code you are running on vxWorks?  If EPICS
is the only source of C++ code in your system then your build system may not
be properly handling the initialization code for C++ static constructors and
destructors, which is what the munch process is for.  This is documented by
Wind River in their VxWorks Kernel Programmers Guide; for vxWorks 6.3 see
section 11.5 "Downloadable Kernel C++ Modules".
> Is it feasible that I copy your built vxTestHarness.munch to my vxWorks
> system, load it, and then run the test commands you've mentioned?
I don't have access to vxWorks 6.3, and I don't think any binary I build using
either vxWorks 5.5.2 or 6.8 would work properly on your version.  You will
have to build EPICS Base yourself using our build system.  You can find
instructions on the tools you need to do that on Windows at
http://www.aps.anl.gov/epics/base/win32.php
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: Does EPICS Base support multi-thread on vxWorks 6.3? Andrew Johnson
Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
Re: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
Prev: Areadetector: driver for Amptek X-123 (DP5) Paul Martin
Next: RE: Alarm Handler and $ALARMCOUNTFILTER keith.baker
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Does EPICS Base support multi-thread on vxWorks 6.3? Andrew Johnson
Next: Re: Does EPICS Base support multi-thread on vxWorks 6.3? Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
