1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Where is histogram?
Date: Thu, 21 Jul 2011 09:56:23 -0400
I started building an IOC using the histogram record and it gave me an "unknown type" error. I checked the
source (I'm using EPICS 3.14.12) and even though the record is defined in <EPICSBASE>/src/rec it's
not included in <EPICSBASE>/src/misc/base.dbd. In fact it's the only record defined in /src/rec that
is not there.
This leads me to a number of questions:
-Is this just a bug? Or is histogram an obsolete record?
-Does this mean nobody is actually using the histogram record?
-If nobody uses histogram, what do they use? Waveform?
Re: Where is histogram? Andrew Johnson
Prev: RE: Areadetector: driver for Amptek X-123 (DP5) Mark Rivers
Next: About CSS/BOY patard
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Where is histogram? Andrew Johnson
