1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Static Linking...
To: David Dudley <[email protected]>
Date: Thu, 21 Jul 2011 12:10:33 -0700
Note however that it's completely possible to link the EPICS libraries statically into an application -- resulting in an executable that depends only on libraries that are part of the standard Mac OS X distributuion. The effect should be much the same as a fully static build -- a distributable binary that runs on all Mac OS X platforms with no other extra effort
http://el-tramo.be/guides/darcs-static-osx
On Jul 21, 2011, at 11:25 AM, David Dudley wrote:
> I seem to have discovered a problem on a MAC darwin-x86 where I can’t static link programs.
> Whenever I try to set STATIC_BUILD=YES in the CONFIG_SITE file, and do a clean rebuild, it fails when it’s trying to link antelope, saying that it can’t find the crt0.0 library.
> Did I delete a file I shouldn’t have, or is this something that darwin-x86 doesn’t support?
> David
> "... The Crossbow Project. There's No Defense Like a Good Offense. " - Real Genius (1985)
> Don't think it exists?  Google the Air Force X-37B project.
Eric Norum
[email protected]
Static Linking... David Dudley
Prev: Re: Static Linking... J. Lewis Muir
Next: Re: Static Linking... Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: color PV in edm Text Monitor Pierrick Hanlet
