1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: question regarding VxStats-1-7-2h (doesn't seem to measure CPU loadproperly)
To: "Jay Steele" <[email protected]>, <[email protected]>
Date: Tue, 26 Jul 2011 07:04:13 -0400
A state transition program that transitions to itself with no delays uses all CPU time that is at the SNL and lower priorities.
I do not recall if the Channel Access Client runs at a lower priority than the state notation engine.
I think that the vxStats gotten from vxWorks are computed in the idle task. That would mean that it would never run.
The better tool for finding this problem is to run the SNL diagnostic, seqShow "state set name".
The current state and the previous state would show the two states (or one if it is to itself), in the infinite loop. And the time in this state will always be zero - or very close to zero.
RE: question regarding VxStats-1-7-2h (doesn't seem to measure CPUloadproperly) Mark Rivers
question regarding VxStats-1-7-2h (doesn't seem to measure CPU load properly) Jay Steele
Prev: Re: question regarding VxStats-1-7-2h (doesn't seem to measure CPU load properly) Ralph Lange
Next: RE: question regarding VxStats-1-7-2h (doesn't seem to measure CPUloadproperly) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: question regarding VxStats-1-7-2h (doesn't seem to measure CPU load properly) Jay Steele
