1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS on OS X Lion -- C++ problem
To: [email protected]
Cc: Eric Norum <[email protected]>
Date: Tue, 26 Jul 2011 16:40:15 -0500
Hi Eric,
On Monday, July 25, 2011 12:54:28 Eric Norum wrote:
> Downloaded and installed OS X Lion and the latest version of Xcode on my
> laptop machine.  Attempting to build EPICS results in:
> /usr/bin/c++ -c -DUNIX  -Ddarwin     -O3 -g   -Wall      -arch i386
> -fno-common -fPIC -MMD -I. -I../O.Common -I. -I..
> -I../../../include/os/Darwin -I../../../include       -I/opt/local/include
> -I/sw/include  ../udpiiu.cpp ../udpiiu.cpp:1391: error: generic thunk code
> fails for method 'virtual int
> udpiiu::printFormated(epicsGuard<epicsMutex>&, const char*, ...)' which
> uses '...'
We've seen this twice now at APS with GCC 4.1.2 built for both the Xilinx and
Altera FPGA-based CPUs.  I managed to narrow the code down to to one simple
file, attached here, which contains valid C++ code but is using some rather
unusual combination of operations (mixing the use of ... with double
inheritance) that requires some thunking code that is often not developed for
new CPUs.  It's basically that whoever wrote the CPU support didn't finish the
job, and EPICS is the first code to notice.
- Andrew (from England, on holiday)
/* Compiling this file with the microblaze version of g++ generates
 * the generic thunk error:
 * rhel6% microblazeel-unknown-linux-gnu-g++ -c broken.cpp
 * broken.cpp:32: error: generic thunk code fails for method
 *     'virtual void C::f(const char*, ...)' which uses '...'
class A {
public:
    virtual ~A () = 0;
class B {
public:
    virtual ~B () = 0;
    virtual void f (const char *, ...) = 0;
class C:
    public A,
    public B {
public:
    virtual ~C ();
    void f (const char *, ...);
void C::f (const char * p, ...)
    // This is line 32
RE: EPICS on OS X Lion -- C++ problem Jeff Hill
EPICS on OS X Lion -- C++ problem Eric Norum
Prev: RE: EPICS on OS X Lion -- C++ problem Jeff Hill
Next: RE: EPICS on OS X Lion -- C++ problem Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
