1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: About CSS/BOY
To: patard <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 27 Jul 2011 13:05:55 -0400
Hi Charles-Henry,
I just added an option "Open in new window" for "Open OPI" action. I think it is reasonable to have this option even though it should not be used too much.
Xihui
-----Original Message-----
Sent: Wednesday, July 27, 2011 11:19 AM
To: [email protected]
Subject: About CSS/BOY
Le 22/07/2011 19:10, Chen, Xihui a écrit :
>  Hi Charles,
>>  I already know this BOY functionality. It's true that my request
>> wasn't quite clear. My aim is to make as simple as possible for
>>  Spiral2 operators and developpers. What could be simplestthan a
>> click  ? I have already written a JavaScript that forces an external
>> window  open when the user simply clicks on the button. I thought
>> that it  could be simpler to add an action property to force an external open.
>  I think the option to open an OPI in a new window should be used wisely, because too many windows will use too much system resources and it is very hard to manage them.
>  Optionally, you can also open an OPI in a View and then you can
> "detach/undetach" the view by right clicking the view tab and select
> "detached". See /BOY Examples/4_Actions_1.opi
>>  I've a other question for you Xihui. Is it possible to prevent the
>> use  of "Opi editor" when the CSS/BOY is in the runtime compact mode
>> ? In  this way the users haven't access to the development tools.
>> They can  only use the "Opi runtime" and can't exit this mode.
>  There is a BOY preference "No-Editing Mode". You can enable it to prevent opening an opi in opi editor.
>  Thanks,
>  Xihui
Hi Xihui,
Thanks for all of your answers. I tested the function of "No-Editing Mode" and "Start application window in compact mode", this is what I expected.
Our working group is in contact with people in charge of application development for ITER. We 're identifying our common need about CSS/BOY.
I'll contact you in a few weeks.
Thanks again for your availability
Charles-Henry
About CSS/BOY patard
Prev: About CSS/BOY patard
Next: Controls Network Monitoring Tools Martin Pieck
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Static Linking... David Dudley
