1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Erros running st.cmd
To: "'Andrew Johnson'" <[email protected]>
Date: Mon, 8 Aug 2011 09:03:26 -0700
Hi Andrew,
Thank you for the assistance/info.  Yes, you were correct.  I've uncommented the makefile statement in question and it helped to resolve my problem.  Bottom line, I am now able to successfully invoke the IOC.
Thanks again,
Flo
-----Original Message-----
Sent: Friday, August 05, 2011 2:18 PM
To: Cid, Florencio A
Cc: [email protected]
Subject: Re: Erros running st.cmd
Hi Florencio,
On 2011-08-05 Cid, Florencio A wrote:
> Andrew, attached is the makefile you requested.  Any help/assistance will
>  be greatly appreciated.
It looks like you've tried to comment out stuff that you don't think you need,
but you actually do need one more thing.  In particular you're not building
the firstioc_registerRecordDeviceDriver.cpp file into your binary, which
contains a static C++ constructor that registers all of the missing commands
with the IOC shell.  You might be able to get away with not adding base.dbd to
firstioc_DBD if you get all of the necessary menu*.dbd files, but you
definitely need the above C++ source file in the firstioc_SRCS list.
Hopefully that fix will be enough to get you going.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Erros running st.cmd Cid, Florencio A
Re: Erros running st.cmd Andrew Johnson
RE: Erros running st.cmd Cid, Florencio A
Prev: RE: Steven Banks passed away last night Andrew C. Starritt
Next: Multi-threaded CAJ Example Ryan Slominski
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Erros running st.cmd Andrew Johnson
Next: Steven Banks passed away last night Richard Farnsworth
