1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM start window position, from command line
Date: Thu, 11 Aug 2011 16:17:50 +1000
Hello,
Further to the discussion in http://www.aps.anl.gov/epics/tech-talk/2011/msg00585.php, I have been trying to open edm windows at specified locations from the command line. I can’t get that to work, but before that, can’t seem to get the edm display file server and related operations to work.
Firstly,
edm –server
or
edm –server –display $DISPLAY
both open an instance of edm.
Subsequently:
edm –x –open file.edl
returns the error “No server found for display - abort”
This error is returned even if the –display option is included before –open
The command
edm –x file.edl
will open another instance of edm, and file.edl as expected. (adding ?X?Y values here doesn’t work)
Without the –open option working, the –open file.edl?X?Y isn’t going to work...
I’ve tried edm versions 1.10.1w, 1.12.39 and 1.12.56.
Many thanks,
Kathryn Spiers
Controls Engineer
Australian Synchrotron
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: EDM start window position, from command line Scott Baily
Prev: Re: question about state notation language logic for when() with delay Benjamin Franksen
Next: devIocStats 3.1.6 released Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: question about state notation language logic for when() with delay Jay Steele
Next: Re: EDM start window position, from command line Scott Baily
