1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues
To: "[email protected]" <[email protected]>, [email protected]
Date: Fri, 19 Aug 2011 10:31:49 -0500
Hello All,
There was a firewall running that I disabled in order to get the command line caget to work. I did have 2 network cards with one if them set to inactive. I removed it to see if that would help but made no difference. I also disabled SELinux to see if that might have been interfering, but no luck. I also tried deleting the IP addresses other then 127.0.0.1 out of the setup. When I do I get another error in the log. I get this message: Failed to create transport for: /127.0.0.1:5064
com.cosylab.epics.caj.impl.ConnectionException: Failed to connect to '/
127.0.0.1:5064'. I am also attaching the whole log that was generated. Thanks for the help everyone.
Cheers,
Adam Gluck | Applications Engineer | National Instruments
Date:        08/19/2011 10:07 AM
Sent by:        [email protected]
Hi:
On 8/19/11 10:49 , "Mark Rivers" <[email protected]> wrote:
> Is there a firewall running on that machine?
I think he said a command-line caget on the same machine worked OK,
but still worth trying.
Does your computer have more than one network card?
> Is there a jcaLibrary.properties file that could be settings things for Java
> differently than the environment variables for the C utilities?
Neither a jcaLibrary.properties file nor environment variables should
matter. CSS is setting the JCA/CAJ libraries from Eclipse preferences
http://sourceforge.net/apps/trac/cs-studio/wiki/HierarchicalPreferences ),
i.e. basically what you see under CSS/Preferences/.../EPICS.
> Thanks for the advice but setting the IP address did not help, I am just
> trying to access the variables on my own machine and have tried localhost
> and 127.0.0.1.
When using CAJ, make sure you try both with and without the "auto" address
list in combination with "127.0.0.1".
> I did try the logging method and saw at first I was not
> linking correctly to a shared library,
> but was able to fix the and no
> longer have the error.
What was that error?
Did that only happen when you selected the JNI version of JCA,
i.e. not the 'pure java' version under CSS/Preferences/.../EPICS
-> That's expected unless you're running on the few architectures
where we have the JNI binaries included.
> I don't see any error message about the PV other
> then it saying it is disconnected. I am attaching my log file to see if
> that might help. Thanks once again for the help.
The log file shows that you're using the "pure Java" JCA.
Also: What's your CA server?
Is it an ordinary IOC, or some other type of CA server?
If you increase the log level (CSS/Preferences/...) to 'FINE' or higher,
you should see more detail:
PV channel created, connected, received meta data, ....
Maybe that'll help.
Kay
2011-08-19 10:26:22.338 SEVERE [Thread 12] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
com.cosylab.epics.caj.impl.ConnectionException: Failed to connect to '/127.0.0.1:5064'.
        at com.cosylab.epics.caj.impl.CAConnector.connect(CAConnector.java:138)
        at com.cosylab.epics.caj.CAJContext.getTransport(CAJContext.java:1438)
        at com.cosylab.epics.caj.CAJContext.searchResponse(CAJContext.java:1415)
        at com.cosylab.epics.caj.impl.handlers.SearchResponse.internalHandleResponse(SearchResponse.java:115)
        at com.cosylab.epics.caj.impl.handlers.AbstractCAResponseHandler.handleResponse(AbstractCAResponseHandler.java:110)
        at com.cosylab.epics.caj.impl.CAResponseHandler.handleResponse(CAResponseHandler.java:122)
        at com.cosylab.epics.caj.impl.BroadcastTransport.processRead(BroadcastTransport.java:201)
        at com.cosylab.epics.caj.impl.BroadcastTransport.handleEvent(BroadcastTransport.java:150)
        at com.cosylab.epics.caj.impl.reactor.lf.LeaderFollowersHandler.handleEvent(LeaderFollowersHandler.java:71)
        at com.cosylab.epics.caj.impl.reactor.Reactor.processInternal(Reactor.java:388)
        at com.cosylab.epics.caj.impl.reactor.Reactor.process(Reactor.java:278)
        at com.cosylab.epics.caj.impl.reactor.lf.LeaderFollowersHandler.run(LeaderFollowersHandler.java:85)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
        at java.lang.Thread.run(Thread.java:662)
Caused by: java.net.UnknownHostException: EPICSlinux: EPICSlinux
        at java.net.InetAddress.getLocalHost(InetAddress.java:1354)
        at com.cosylab.epics.caj.impl.requests.HostNameRequest.<init>(HostNameRequest.java:42)
        at com.cosylab.epics.caj.impl.CAConnector.connect(CAConnector.java:121)
        ... 14 more
2011-08-19 10:26:22.365 SEVERE [Thread 15] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
2011-08-19 10:26:22.395 SEVERE [Thread 14] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
2011-08-19 10:26:22.426 SEVERE [Thread 13] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
2011-08-19 10:26:22.460 SEVERE [Thread 11] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
2011-08-19 10:26:22.491 SEVERE [Thread 12] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
2011-08-19 10:26:22.523 SEVERE [Thread 15] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
2011-08-19 10:26:22.553 SEVERE [Thread 14] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
2011-08-19 10:26:22.583 SEVERE [Thread 12] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
2011-08-19 10:26:22.613 SEVERE [Thread 11] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
2011-08-19 10:26:22.644 SEVERE [Thread 13] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
2011-08-19 10:26:23.065 SEVERE [Thread 15] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
2011-08-19 10:26:23.092 SEVERE [Thread 14] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
        ... 14 more
Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Kasemir, Kay
RE: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Mark Rivers
Prev: Re: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading J. Lewis Muir
Next: Re: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Kasemir, Kay
Next: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Kasemir, Kay
