1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Building EPICS (3-14-12-1) on Windows 7
To: Jeff Hill <[email protected]>
Date: Fri, 19 Aug 2011 10:01:49 -0700
Jeff Hill wrote:
Ernest,
1>     Creating library com.lib and object com.exp
1>fdManager.obj : error LNK2001: unresolved external symbol
___WSAFDIsSet@8
I typed this command "mingw-get update mingw32-make" and now my mingw make
3.82 appears to be working just fine. I suspect that I am just now seeing
this issue because I merged in some R3.15 build system changes yesterday,
and R3.15 maybe uses the gnu make variable "$*" more than past releases of
the build system. The mingw32-make 3.81 also works fine here.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
Well, thanks Jeff for helping with this one. I would like to also thank others who offered their experience as well.
My solution was slightly different as there are many versions of mingw32-make floating around on SourceForge. :( The following install package from SourceForge did not work to build EPICS: "mingw-get-inst-20110802.exe"
I just pick from there list the earliest version: "mingw-get-inst-20100831.exe"
Now, EPICS builds like a charm  :)
The list of MinGW installers was found at the link below:
http://sourceforge.net/projects/mingw/files/Automated%20MinGW%20Installer/mingw-get-inst
Conclusion: Fully patched version of EPICS -- base-R3-14-12-1 builds for me on Windows 7 x86 (32-bit)
I expect to try under Windows 7 (64-bit) next.
Cheers,
Ernest
-----Original Message-----
Sent: Thursday, August 18, 2011 4:44 PM
To: 'Jeff Hill'; 'Andrew Johnson'
Cc: 'Ernest L. Williams Jr.'; 'Janet Anderson'
Subject: RE: Building EPICS (3-14-12-1) on Windows 7
Closing in.
I added "$(ECHO) $* $@" to the share lib build line below (because I can
see that the win32 Link.shrlib uses $*) and I see that "$(ECHO) $* $@"
produces "com Com.dll" with mingw gnu make 3.82.
$(SHRLIBNAME) $(TESTSHRLIBNAME):$(SHRLIB_PREFIX)%$(SHRLIB_SUFFIX):
      @$(RM) $@
      $(ECHO) $* $@
      $(LINK.shrlib)
ifeq ($(SHRLIB_SUFFIX),.dll)
      $(MT_DLL_COMMAND)
endif
And this is what the gnu make doc says:
    The stem with which an implicit rule matches (see How Patterns Match).
If the target is dir/a.foo.b and the target pattern is a.%.b then the stem
is dir/foo. The stem is useful for constructing names of related files. In
a static pattern rule, the stem is part of the file name that matched the
‘%’ in the target pattern.
    In an explicit rule, there is no stem; so ‘$*’ cannot be determined in
that way. Instead, if the target name ends with a recognized suffix (see
Old-Fashioned Suffix Rules), ‘$*’ is set to the target name minus the
suffix. For example, if the target name is ‘foo.c’, then ‘$*’ is set to
‘foo’, since ‘.c’ is a suffix. GNU make does this bizarre thing only for
compatibility with other implementations of make. You should generally
avoid using ‘$*’ except in implicit rules or static pattern rules.
    If the target name in an explicit rule does not end with a recognized
suffix, ‘$*’ is set to the empty string for that rule.
Jeff
Sent: Thursday, August 18, 2011 4:27 PM
To: 'Andrew Johnson'
And I now see that the difference between IDE and DOS command line is in
fact caused by a different GNU make. The build works under GNU Make 3.81
but not under 3.82 (both are mingw versions)
C:\hill\epicsInBazaar\cvs-trunk\src\libCom>gmake -v
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i686-pc-mingw32
C:\hill\epicsInBazaar\cvs-trunk\src\libCom>mingw32-make -v
GNU Make 3.82
Built for i386-pc-mingw32
Copyright (C) 2010  Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Jeff
Sent: Thursday, August 18, 2011 4:09 PM
which I merged into the 3.15 branch yesterday
Ahh ... I see it now after updating my R3.15 mirror.
BTW: I now see Earnest's link time issue also, but only when building
in
the IDE and not when building on the command line so I suspect based
on
past experience with (.c vs ..C) that we have another case sensitivity
issue riding on the version of make (i.e. Com vs com causes the
windsock
library to not be included on the link line). Suspect also that my
R3.15
merge yesterday has caused this issue to show up.
In the IDE:
1>  link /nologo /subsystem:windows /dll /LTCG /incremental:no
/opt:ref
/release /version:3.15 /fixed:no /debug    /implib:com.lib
/out:com.dll
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\bucketLib.obj
x86\epicsRingPointer.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\epicsRingBytes.obj
trunk\src\libCom\O.win32-x86\postfix.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\calcPerform.obj
trunk\src\libCom\O.win32-x86\cvtFast.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\resourceLib.obj
trunk\src\libCom\O.win32-x86\epicsThrowTrace.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\dbmf.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\ellLib.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\envSubr.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\envData.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\errlog.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\errSymLib.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\errSymTbl.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\fdmgr.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\fdManager.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\freeListLib.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\gpHashLib.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\iocsh.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\registry.obj
x86\libComRegister.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\iocLog.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\logClient.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\macCore.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\macEnv.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\macUtil.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\aToIPAddr.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\adjustment.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\cantProceed.obj
x86\epicsConvert.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsExit.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsStdlib.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsString.obj
x86\truncateFile.obj
x86\ipAddrToAsciiAsynchronous.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\epicsUnitTest.obj
trunk\src\libCom\O.win32-x86\epicsThread.obj
trunk\src\libCom\O.win32-x86\epicsMutex.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\epicsOsiMutexThreadPrivate.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsEvent.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsTime.obj
x86\epicsMessageQueue.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\epicsMath.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\epicsAtomicLocked.obj
x86\epicsAtomicOSD.obj
x86\epicsOsiStaticInstanceSketchyCmplr.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\epicsGeneralTime.obj
x86\osiClockTime.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\osdSock.obj
x86\osdSockAddrReuse.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osiSock.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\systemCallIntMech.obj
x86\epicsSocketConvertErrnoToString.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osdAssert.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osdFindSymbol.obj
trunk\src\libCom\O.win32-x86\osdInterrupt.obj
trunk\src\libCom\O.win32-x86\osdPoolStatus.obj
trunk\src\libCom\O.win32-x86\osdSignal.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osdEnv.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\epicsReadline.obj
trunk\src\libCom\O.win32-x86\epicsTempFile.obj
trunk\src\libCom\O.win32-x86\epicsStdio.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osdStdio.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osdThread.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osdMutex.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osdEvent.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osdTime.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osdProcess.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osdNetIntf.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\osdMessageQueue.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\devLibVME.obj
x86\devLibVMEOSD.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\taskwd.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsTimer.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\timer.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\timerQueue.obj
x86\timerQueueActive.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\timerQueueActiveMgr.obj
x86\timerQueuePassive.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\yajl.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\yajl_alloc.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\yajl_buf.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\yajl_encode.obj
trunk\src\libCom\O.win32-x86\yajl_gen.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\yajl_lex.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\yajl_parser.obj
trunk\src\libCom\O.win32-x86\ConString.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\SegString.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\VariableString.obj
trunk\src\libCom\O.win32-x86\ChunkedString.obj
trunk\src\libCom\O.win32-x86\SegTree.obj C:\hill\epicsInBazaar\cvs-
trunk\src\libCom\O.win32-x86\stringReaderHash.obj
C:\hill\epicsInBazaar\cvs-trunk\src\libCom\O.win32-x86\epicsGetopt.obj
x86\setThreadName.obj
x86\forceBadAllocException.obj
___WSAFDIsSet@8
__imp__WSAGetLastError@0
__imp__select@20
1>logClient.obj : error LNK2001: unresolved external symbol
__imp__send@16
__imp__setsockopt@20
__imp__shutdown@8
__imp__htons@4
__imp__connect@12
1>aToIPAddr.obj : error LNK2001: unresolved external symbol
__imp__htonl@4
1>osdSock.obj : error LNK2001: unresolved external symbol
__imp__accept@12
__imp__gethostbyname@4
__imp__gethostbyaddr@12
__imp__closesocket@4
__imp__socket@12
__imp__WSACleanup@0
__imp__WSAStartup@8
1>osiSock.obj : error LNK2001: unresolved external symbol
__imp__ntohs@4
__imp__ntohl@4
1>osdProcess.obj : error LNK2001: unresolved external symbol
__imp__MessageBoxA@16
__imp__GetUserNameA@8
1>osdNetIntf.obj : error LNK2001: unresolved external symbol
__imp__WSAIoctl@36
1>com.dll : fatal error LNK1120: 21 unresolved externals
Dos command line:
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0
/D_CRT_SECURE_NO_DEPRECATE  /D_CRT_NONSTDC_NO_DEPRECATE
/D_SCL_SECURE_NO_WARNINGS   /Ox /GL /Zi   /W3 /w44355       /MD  /TP
I.
-I..\O.Common -I.
i\compiler\msvc -I..\..\..\src\libCom\osi\compiler\default -I. -
I..\..\..\src\libCom\osi\os\WIN32 -I..\..\..\src\libCom\osi\os\default
I.. -I..\..\..\src\libCom\bucketLib -I..\..\..\src\libCom\ring -
I..\..\.
.\..\src\libCom\cvtFast -I..\..\..\src\libCom\cppStd -
I..\..\..\src\libCom\cxxTemplates -I..\..\..\src\libCom\dbmf -
I..\..\..\src\libCom\ellLib -I..\..\..\src\libCom\env -
I..\..\..\src\libCom\error -I..\..\..
.\..\src\libCom\freeList -I..\..\..\src\libCom\gpHash -
I..\..\..\src\libCom\iocsh -I..\..\..\src\libCom\logClient -
I..\..\..\src\libCom\macLib -I..\..\..\src\libCom\misc -
I..\..\..\src\libCom\osi -I..\..\..\s
\..\src\libCom\timer -I..\..\..\src\libCom\yajl -
I..\..\..\src\libCom\BaseString -I..\..\..\include\compiler\msvc -
I..\..\..\include\os\WIN32 -I..\..\..\include
AllocException.cpp
forceBadAllocException.cpp
link /nologo /subsystem:windows /dll /map /LTCG /incremental:no
/opt:ref
/release /version:3.15 /fixed:no /debug    /implib:Com.lib
/out:Com.dll
bucketLib.obj epicsRingPointer.obj epicsRingBytes.obj
obj cvtFast.obj resourceLib.obj epicsThrowTrace.obj dbmf.obj
ellLib.obj
envSubr.obj envData.obj errlog.obj errSymLib.obj errSymTbl.obj
fdmgr.obj
fdManager.obj freeListLib.obj gpHashLib.obj iocsh.obj registry.
ocLog.obj logClient.obj macCore.obj macEnv.obj macUtil.obj
aToIPAddr.obj
adjustment.obj cantProceed.obj epicsConvert.obj epicsExit.obj
epicsStdlib.obj epicsString.obj truncateFile.obj
epicsThread.obj epicsMutex.obj epicsOsiMutexThreadPrivate.obj
epicsEvent.obj epicsTime.obj epicsMessageQueue.obj epicsMath.obj
epicsAtomicLocked.obj epicsAtomicOSD.obj
epicsOsiStaticInstanceSketchyCmplr.obj e
lockTime.obj osdSock.obj osdSockAddrReuse.obj osiSock.obj
systemCallIntMech.obj epicsSocketConvertErrnoToString.obj
osdAssert.obj
osdFindSymbol.obj osdInterrupt.obj osdPoolStatus.obj osdSignal.obj
osdEnv.obj
empFile.obj epicsStdio.obj osdStdio.obj osdThread.obj osdMutex.obj
osdEvent.obj osdTime.obj osdProcess.obj osdNetIntf.obj
osdMessageQueue.obj
devLibVME.obj devLibVMEOSD.obj taskwd.obj epicsTimer.obj timer.obj
ueActive.obj timerQueueActiveMgr.obj timerQueuePassive.obj yajl.obj
yajl_alloc.obj yajl_buf.obj yajl_encode.obj yajl_gen.obj yajl_lex.obj
yajl_parser.obj ConString.obj SegString.obj VariableString.obj Chunked
tringReaderHash.obj epicsGetopt.obj setThreadName.obj
forceBadAllocException.obj Com.res     ws2_32.lib advapi32.lib
user32.lib
   Creating library Com.lib and object Com.exp
Generating code
Finished generating code
"Installing shared library ../../../bin/win32-x86/Com.dll"
"Installing library ../../../lib/win32-x86/Com.lib"
gmake[1]: Leaving directory `C:/hill/epicsInBazaar/cvs-
trunk/src/libCom/O.win32-x86'
Jeff
Sent: Thursday, August 18, 2011 2:28 PM
To: Jeff Hill
Hi Jeff,
On 2011-08-18 Jeff Hill wrote:
Janet: should we remove this rule from R3.15 and R3.14, and if so
who
will
take care of this (me or you)?
It has already gone in both branches, see commit 12247 in the 3.14
branch
which I merged into the 3.15 branch yesterday (commit 12207.1.40
there),
and
if Ernest has applied all the Known Problems patches then this patch
    http://www.aps.anl.gov/epics/base/R3-14/12-docs/C-rule.patch
will have already removed it for him too.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Building EPICS (3-14-12-1) on Windows 7 Williams Jr., Ernest L.
RE: Building EPICS (3-14-12-1) on Windows 7 Jeff Hill
Prev: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Kasemir, Kay
Next: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Adam Gluck
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Building EPICS (3-14-12-1) on Windows 7 Jeff Hill
Next: CSS EPICS PV connectivity issue Chen Xue
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
