1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Reboot VME problem
To: Chen Xue <[email protected]>
Cc: [email protected]
Date: Wed, 24 Aug 2011 15:43:10 -0500
On 8/24/11 3:29 PM, Chen Xue wrote:
> Hi, there,
> I have a host machine and MVME 5100 card in a crate. Everything
> worked fine before I moved both of them to a new place. After I
> shut off the machine and crate and moved to another place, I
> can't reboot the IOC. The error message is 'Error in boot
> line'... 'Can't load boot file'. Could someone help me to fix
> the problem?
Hi, Chen.
Can you post the actual error message?
Are you booting from NFS or FTP?
Is the network cable plugged in?
Is the MVME 5100 on the same network as it was before?  If not,
you may need to change the settings for the network adapter at
the firmware prompt.
Can you check the access log of the NFS or FTP server to ensure
the MVME 5100 is successfully connecting to obtain the boot image?
Lewis
Reboot VME problem Chen Xue
Prev: Reboot VME problem Chen Xue
Next: Newbe question - PV limits Paul Nord
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
