1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Newbe question - PV limits
To: Paul Nord <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 24 Aug 2011 14:49:28 -0700
Hi Paul,
It is helpful to know the OS and version of EPICS base that you are using.  Also provide the output from the full dbpr results from the IOC:
dbpr("GROUP_0", 5)
Thank you,
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Paul Nord
> Sent: Wednesday, August 24, 2011 2:10 PM
> To: [email protected]
> Subject: Newbe question - PV limits
> I've got a GUI setup with MEDM to control some values.  I'd like to PV to accept values
> only in a valid range: 4 or 5.
> Here's the record:
> record(longout, "GROUP_0")
>  field(DESC, "SNMP channel BBM-")
>  field(DTYP, "Snmp")
>  field(SCAN, "Passive")
>  field(EGU,  "")
>  field(PINI, "YES")
>  field(OUT,  "@$(HOST) guru WIENER-CRATE-MIB::groupsSwitch.0 INTEGER: 100
> i")
>  field(ADEL, "1")
>  field(VAL, "5")
>  field(LOPR, "5")
>  field(HOPR, "4")
>  field(DRVH, "5")
>  field(DRVL, "4")
> I've tried setting LOPR, HOPR, and DRV*.  But I can still sent "1" from MEDM and it
> will set the hardware into an undesired mode.
> I must be missing something simple here.
> Paul
Newbe question - PV limits Paul Nord
Prev: ether_ip driver for ControlLogix PLCs and 'BOOL' tags Kasemir, Kay
Next: Re: Newbe question - PV limits Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Newbe question - PV limits Paul Nord
