1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Newbe question - PV limits
To: Paul Nord <[email protected]>
Cc: [email protected]
Date: Thu, 25 Aug 2011 10:30:29 -0700
> I've tried setting LOPR, HOPR, and DRV*.  But I can still sent "1" from MEDM and it will set the hardware into an undesired mode.
As far as I known LOPR,HOPR are only used for display.
DRVH and DRVL are the hard limit.
In you dbpr, I see VAL at 4... not at 1.
Maybe 4 is what makes your driver go in the undesired mode.
Check your driver code!
Also just out of curiosity, what is the value of RVAL (if there is such a field for longout)?
> I must be missing something simple here.
> Paul
Emmanuel
Newbe question - PV limits Paul Nord
Prev: Re: 'open' epics backup? emmanuel_mayssat
Next: Re: 'open' epics backup? Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Newbe question - PV limits Paul Nord
Next: ether_ip driver for ControlLogix PLCs and 'BOOL' tags Kasemir, Kay
