1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Configuring an IOC to -not- build for host arch
To: "Vigder, Mark" <[email protected]>
Cc: [email protected]
Date: Wed, 31 Aug 2011 17:17:01 -0500
Hi Mark,
On 2011-08-31 Vigder, Mark wrote:
> This problem seems to have been discussed about a year ago,
> (http://www.aps.anl.gov/epics/tech-talk/2010/msg01432.php) but I still
>  can't solve it. I have a linux-x86_64 host and a linux-x86 target. I want
>  to build IOC's and libraries for the target only, not for the host.
> As mentioned below, both my host and target have the same OS class, so I
> can't use the PROD_IOC_<osclass> to differentiate them.
> I tried the BUILD_FOR_HOST_ARCH set to the empty string as suggested below.
> I set that variable in the IOC's '<TOP>/configure/CONFIG_SITE'. But that
> still built for the host as well as the target.
Use something like this in your Makefile:
PROD_IOC_linux-x86 = <products you want to build here>
PROD_IOC += $(PROD_IOC_$(T_A))
That adds the list of products to PROD_IOC only when T_A is linux-x86; for
other values of T_A they will not be included.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: Configuring an IOC to -not- build for host arch Vigder, Mark
Prev: Re: Advantech USB-4700 Series Pete R. Jemian
Next: EPICS Soft IOC question Andrew Cox
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Configuring an IOC to -not- build for host arch Vigder, Mark
