1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Soft IOC question
To: Andrew Cox <[email protected]>
Cc: [email protected]
Date: Thu, 1 Sep 2011 08:45:28 -0700
Try this... and see what comes out!
${EPICS_BASE}/bin/${EPICS_HOST_ARCH}/makeBaseApp.pl -t example base
${EPICS_BASE}/bin/${EPICS_HOST_ARCH}/makeBaseApp.pl -i -t example -a ${TARGET_ARCH} base
I have my own directory structure in my SVN tree.
I built my own makefiles.
No sure you want to do that for only a few IOCs.
The directory structure I have is as follow
.../svn/<synchrotronId>/drivers/<driverName>/{db|doc|medm|qt|msi|iocBoot|dbd|medm|stream|src|...}/
.../svn/<synchrotronId>/iocs/<iocName>/{db|doc|medm|iocBoot|dbd|msi|medm|qt|src|...}/
.../svn/<synchrotronId>/opis/<opiSoftware>/{bin|etc|...}/
The Makefiles build, configure, and install the software based on hostname, arch, etc...
So yes, you can make it as complicated as you want ;-)
Good luck,
E
On 16:02 Wed 31 Aug     , Andrew Cox wrote:
> Hi,
> I have downloaded the EPICS IOC core on a redhat machine. I need to run
> atleast 3-4 soft IOc on this machine, but i am not able to decide on the
> directory structure. i do not want it to be complicated. Can anyone help me
> with a directory structure for the database, drivers etc ?
> Thanks,
> Andrew
Emmanuel
Re: EPICS Soft IOC question Bruce Hill
EPICS Soft IOC question Andrew Cox
Prev: EPICS Soft IOC question Andrew Cox
Next: CA issues on Linux Cid, Florencio A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS Soft IOC question Bruce Hill
