1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Another newbie question - seq record example?
To: Paul Nord <[email protected]>
Cc: [email protected]
Date: Mon, 12 Sep 2011 21:29:28 -0400
Paul,
Many ways to do this, without knowing your system's needs I'll give a
simple, slow way, which should get you closer:
Assume Trip/Reset is a BI record that refelects your hardware.
BI record: Link BI's VAL to INPA of CALCOUT record (NPP MS).
CALC record: SCAN 1 Hz, CALC is A?1:0 , output on transition 0->1, OUT
link to the PROC of a SEQ record (PP MS) , don't drive output on
INVALID severity.
SEQ record: SCAN passive, put in the DLY you want, LNKA to your AO
record's PROC (PP MS).
AO record: SCAN passive, output slew rate and drive limits?,
Closed_Loop mode and a DOL link to the voltage you want (or have SEQ
LNK to VALV if using supervisory mode)., don't drive outputs on
INVALID severity.
On Mon, Sep 12, 2011 at 17:47, Paul Nord <[email protected]> wrote:
> Good Day,
> I'm in a hurry to implement some more complicated control for a HV power supply.  I've got all of the basic functions running  (asyn device).
> I need to automate a trip reset.  Does someone have something like this?  The seq record example in the EPICS doc's is pretty trivial.
>        On Trip -> Reset
>        Delay
>        Ramp back to voltage setting
> Thanks,
> Paul Nord
Another newbie question - seq record example? Paul Nord
Prev: Another newbie question - seq record example? Paul Nord
Next: Re: Another newbie question - seq record example? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
