1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Radhard potentiometers?
From: "Molina Marinas, Eduardo" <[email protected]>
To: <[email protected]>
Date: Tue, 13 Sep 2011 09:44:25 +0200
Title: Radhard potentiometers?
Hello,
our group is working on a scraper for the IFMIF-EVEDA project. We are looking for an adequate position sensor able to withstand high doses of neutrons, in a linear configuration (no shaft coupled). After searching in the list, it seems that potentiometers could do the job (accuracy and repeatibility should be in the 0.01 mm range) Could anyone suggest a particular manufacturer or product?
Thank you,
Eduardo Molina
CIEMAT
Avda.Complutense 40
ES-28040 Madrid
---------------------------- Confidencialidad: Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su destinatario y puede contener información privilegiada o confidencial. Si no es vd. el destinatario indicado, queda notificado de que la utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente respondiendo al mensaje y proceda a su destrucción. Disclaimer: This message and its attached files is intended exclusively for its recipients and may contain confidential information. If you received this e-mail in error you are hereby notified that any dissemination, copy or disclosure of this communication is strictly prohibited and may be unlawful. In this case, please notify us by a reply and delete this email and its contents immediately. ----------------------------
Re: Radhard potentiometers? S. Stein
RE: Radhard potentiometers? Sarkar, Surajit
Prev: Re: Another newbie question - seq record example? Ralph Lange
Next: Re: Radhard potentiometers? S. Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Another newbie question - seq record example? Paul Nord
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
