1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA Repeater Problem with new installation of EPICS
Date: Tue, 13 Sep 2011 15:13:19 +0200
Hello
I am new to EPICS. I have built the EPICS base R-3.14.12.1 successfully for Scientific Linux 5.
While I created the first application (as advised in Application Developer’s Guide) and it looks running without problem.
However when I build the caClient example and tried to run caExample I observe the following messages:
./caExample rootHost:ai3
**** The executable "caRepeater" couldn't be located
**** because of errno = "No such file or directory".
**** You may need to modify your PATH environment variable.
**** Unable to start "CA Repeater" process.
rootHost:ai3 3.000000
Also when I start edm for an application here, I notice the same message.
Can anyone help me to find what may be the possible fault in my EPICS installation.
With Regards
Zia-ul-Haque Qazi
Control Engineer
Synchrotron-light for Experimental Sciences and Applications in the Middle East (SESAME)
P. O. Box 7, Allan 19252, Jordan
Phone: +962-5-3511348    Ext: 239
Cell:      +962-79-5295527
Fax:       +962-5-3511423
RE: CA Repeater Problem with new installation of EPICS Mark Rivers
Prev: RE: CA Repeater Problem with new installation of EPICS Mark Rivers
Next: RE: Radhard potentiometers? Sarkar, Surajit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Radhard potentiometers? Eduardo Molina
Next: RE: CA Repeater Problem with new installation of EPICS Mark Rivers
