1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asynUInt32Digital write callback function not called
To: Eric Norum <[email protected]>
Date: Wed, 5 Oct 2011 06:50:26 +0000
Thanks a lot Eric.
This solved the issue.
Best Regards,
Sébastien PELLÉ
Tel : +33 (0)4 76 61 87 09
Fax : +33 (0)4 76 41 47 47
[email protected]
36, chemin du vieux chêne
BP 104
38243 Meylan Cedex
-----Message d'origine-----
De : [email protected] [mailto:[email protected]] De la part de Eric Norum
Envoyé : mardi 4 octobre 2011 18:08
À : PELLE Sébastien
Cc : [email protected]
Objet : Re: asynUInt32Digital write callback function not called
Having SCAN="I/O Intr" is somewhat unusual for output records.   Are you sure this is what you want?  I ask this because it is the reason that you don't see the record process when you write to it -- 'process on write' occurs only if SCAN="Passive".
On Oct 4, 2011, at 6:20 AM, PELLE Sébastien wrote:
> Hello,
> I am currently writing an EPICS device support using the asyn framework.
> I have an issue : when writing the PV, It does not fall into the write function whereas the write function is called during iocInit (PINI = 1).
> Here is my record (I have some other like this) :
> record(bo, "$(P)$(R)boDevice_Status_ColdReset")
>    field(PINI, "1")
>    field(DTYP, "asynUInt32Digital")
>    field(OUT,  "@asynMask($(PORT),$(ADDRESS),0x00000001,$(TIMEOUT))BODEVICE_STATUS_COLDRESET")
>    field(SCAN, "I/O Intr")
>    field(ONAM, "Device Cold Reset")
>    field(ZNAM, "Nothing will happen")
> When writing to it (dbpf <portName>: boDevice_Status_ColdReset 1) the my writeUInt32Digital is not called. No idea why.
> I tried with the SCAN field = 1 second : the write function is called every second. However, this is not the behavior I want.
> Does anyone have any idea why this write function is not called ?
> Thanks a lot,
> Best Regards,
> Sébastien PELLÉ
> [email protected]
> BP 104
> 38243 Meylan Cedex
> ________________________________
> Ce message et les pièces jointes sont confidentiels et réservés à l'usage exclusif de ses destinataires. Il peut également être protégé par le secret professionnel. Si vous recevez ce message par erreur, merci d'en avertir immédiatement l'expéditeur et de le détruire. L'intégrité du message ne pouvant être assurée sur Internet, la responsabilité du groupe Atos ne pourra être engagée quant au contenu de ce message. Bien que les meilleurs efforts soient faits pour maintenir cette transmission exempte de tout virus, l'expéditeur ne donne aucune garantie à cet égard et sa responsabilité ne saurait être engagée pour tout dommage résultant d'un virus transmis.
> This e-mail and the documents attached are confidential and intended solely for the addressee; it may also be privileged. If you receive this e-mail in error, please notify the sender immediately and destroy it. As its integrity cannot be secured on the Internet, the Atos group liability cannot be triggered for the message content. Although the sender endeavors to maintain a computer virus-free network, the sender does not warrant that this transmission is virus-free and will not be liable for any damages resulting from any virus transmitted.
Eric Norum
[email protected]
asynUInt32Digital write callback function not called PELLE Sébastien
Re: asynUInt32Digital write callback function not called Eric Norum
Prev: RE: Re: Sequence monitor not getting callback Shankar, Murali
Next: Re: Add new Alarm Status Schoeneburg, Bernd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asynUInt32Digital write callback function not called Eric Norum
Next: Building Static binaries David Dudley
