1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: event record priority
To: "John Dobbins" <[email protected]>, "EPICS Tech-Talk" <[email protected]>
Date: Thu, 13 Oct 2011 15:05:20 +0200
Hi John,
Yes, there is. Just set the "PRIO" field to HIGH to get your event record processed in cbHigh. By default (if you do not set PRIO) it is set to LOW.
Babak
-----Original Message-----
Sent: Thu 10/13/2011 2:37 PM
To: EPICS Tech-Talk
Subject: event record priority
All,
I am using an Event record to trigger processing of a number of other records. If I set .TPRO on the Event record or one of the triggered records I see that these records are on scan task cbLow. Is there a simple way to change the priority associated with an Event record?
John Dobbins
Cornell Laboratory for Accelerator-based Sciences and Education
Cornell University
Ithaca, NY
event record priority John Dobbins
Prev: event record priority John Dobbins
Next: Re: Sequence monitor not getting callback J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS driver for acqiris cPCI digitizer is available on epics.sf.net Hu, Yong
