1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Sequence monitor not getting callback
To: "J. Lewis Muir" <[email protected]>
Date: Thu, 13 Oct 2011 11:27:44 -0700
Thank you. I tried this out on my dev box and /proc/cpuinfo happily reports only one CPU.
The test with CA alone performs better in that it succeeds about 50% of the time. But a little less than 50% of the time, I still get monitors that have not received callbacks.
The original test with sequence programs performs much better. So far, I have been able to reproduce the issue only once in about 10 tests. But the issue still occurs.
I have attached the thread dumps as well.
Murali
-----Original Message-----
Sent: Thursday, October 13, 2011 7:52 AM
To: Shankar, Murali
Cc: Jeff Hill; [email protected]
Subject: Re: Sequence monitor not getting callback
On 10/12/11 7:15 PM, Shankar, Murali wrote:
> Ernest says he'll help me run this on an single core RTEMS box
> and if possible, a single core VXworks box tomorrow morning.
> I'll post the results here. If I can find a single core linux
> box somewhere, I'll try this out there as well.
Hi, Murali.
I haven't tried it, but I think many SMP Linux kernels support
the 'maxcpus' boot parameter (or the older 'nosmp' boot
parameter).  So perhaps you could use this option to effectively
change your Linux box into a single CPU box for your test?
See
http://www.kernel.org/doc/Documentation/kernel-parameters.txt
and the bootparam(7) man page.
Lewis
Attachment: GDBThreadST_Oct13_2011.tar.gz
Description: GDBThreadST_Oct13_2011.tar.gz
Re: Sequence monitor not getting callback Benjamin Franksen
RE: Sequence monitor not getting callback Jeff Hill
Re: Sequence monitor not getting callback Shankar, Murali
RE: Sequence monitor not getting callback Shankar, Murali
Re: Sequence monitor not getting callback J. Lewis Muir
Prev: EPICS driver for acqiris cPCI digitizer is available on epics.sf.net Hu, Yong
Next: Re: Sequence monitor not getting callback Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequence monitor not getting callback J. Lewis Muir
