1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: How the EPICS IOC determines the link type {CA_LINK/DB_LINK/CONSTANT}
To: EPICS <[email protected]>
Date: Mon, 17 Oct 2011 15:32:08 +0200
Hi all
I had a quick look at the epics base code but i could not find where the link type was set.
What I mean is the following:
In the dbd file, there are some record types which have some fields of type INLINK/OUTLINK/FWDLINK.
Depending on the cases, it can point to a constant (like DOL field for instance) or to a timestamp (TSE) or to a real PV.
When I looked at the code, there is a notion of link type associated with this type of fields and a link type can be either CA_LINK/CONSTANT/DB_LINK/PV_LINK(=DB+CA_LINK).
However I didn't find where and how the links were set at IOC start up. I'm really interesting in knowing how the IOC knows if the field points to a real PV...
Thanks a lot for your help
Lana
Re: How the EPICS IOC determines the link type {CA_LINK/DB_LINK/CONSTANT} Andrew Johnson
EPICS Workshop Fall 2011 Dirk Zimoch
Prev: EPICS Workshop Fall 2011 Dirk Zimoch
Next: Re: How the EPICS IOC determines the link type {CA_LINK/DB_LINK/CONSTANT} Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
