1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: aSub and zero length arrays
Date: Tue, 18 Oct 2011 11:09:06 -0400
I've stumbled onto an interesting behavior of aSub. I want to write a function which takes a CHAR array as input (a long string). Sometimes the string can legitimately be empty (length 0). What I find is that when the the input should go from non-empty to empty it does not, and instead keeps the previous value.
In aSubRecord.c I see the following
for (i = 0; i < NUM_ARGS; i++) {
        long nRequest = (&prec->noa)[i];
status = dbGetLink(&(&prec->inpa)[i], (&prec->fta)[i], (&prec->a)[i], 0,
&nRequest);
        if (nRequest > 0)
            (&prec->nea)[i] = nRequest;
        if (status)
            return status;
http://bazaar.launchpad.net/~epics-core/epics-base/3.15/view/head:/src/std/rec/aSubRecord.c#L321
I think what I am seeing is due to the "if (nRequest > 0)" test.
Is it ever the case that status==0 and nRequest==0 is used to signal an error? If not then can this be changed? Perhaps to:
&nRequest);
        if (status)
            return status;
        else
It looks like subArray does the right thing. However, soft device support for waveform, and aai don't. They actually ignore status completely!
http://bazaar.launchpad.net/~epics-core/epics-base/3.15/view/head:/src/std/dev/devWfSoft.c#L72
Michael
Re: aSub and zero length arrays Andrew Johnson
Prev: Re: Fwd: FW: EPICS driver for acqiris cPCI digitizer is available on epics.sf.net Silver
Next: Re: aSub and zero length arrays Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
