1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: EZCA and ezcaIDL improvements?
To: <[email protected]>
Date: Tue, 18 Oct 2011 18:19:01 -0500
Folks,
Andrew Johnson thought he remembered someone at the recent EPICS collaboration meeting talking about improvements to the EZCA extension to use 3.14 preemptive callbacks.  Has someone done some work on this?
Here’s why I want to know:
Thanks to help from Andrew I just discovered that the IDL interface (and probably other scripting languages like Matlab, etc.) can cause serious problems with an EPICS IOC.  The problem arises when the IDL client sets monitors on a PV (with caSetMonitor()), but then does not call ca_pend_event() frequently.  ca_pend_event() is called by the “caGet”, “caPut”, “cacheckMonitor”, etc. functions in IDL.  But if one calls caSetMonitor() and then just sits at the IDL prompt, ca_pend_event() is not being called.  When that happens the CA server is trying to send monitor events to the client.  These initially queue up on the client side, but eventually they begin to queue up on the server side.  As they queue on a vxWorks server they consume mbufs.  I have found that a single client in this state will consume all of the 256 byte clusters, and some of the 512 byte clusters.  If a few more clients are in this state then there are no mbufs available above a certain size.  When that happens no new CA connections can be made, other network services fail, etc.
I think this problem could be avoided if we changed the ezca C library that IDL calls to use preemptive callbacks, so that periodic calls to ca_pend_event are no longer needed.
RE: EZCA and ezcaIDL improvements? Mark Rivers
Prev: Re: Build EPICS base-3.14.12.1-T222 in Linux problem. Ron Sluiter
Next: cagateway: building with CMake, creating Debian/RPM packages Martin Konrad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: EZCA and ezcaIDL improvements? Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
