1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cagateway: building with CMake, creating Debian/RPM packages
To: [email protected]
Date: Wed, 19 Oct 2011 09:04:35 +0200
On Wed Oct 19 2011 01:34:02 GMT+0200 (CEST), Martin Konrad
<[email protected]> wrote:
> It's possible to build cagateway on Debian/Ubuntu against Michael
> Davidsaver's Debian packages. Just make sure you have epics-pcas-dev
> installed.
> I still don't understand why casCtx.h is included by cagateway while it
> is not installed into the include directory of base. To me this seems to
> be a bug either in cagateway or base. Handling this situation becomes
> more difficult with 3.15 because the file has been moved to another
> directory in this revision. Can someone help to resolve this issue? Does
> it make sense to add this file to the include directory in 3.15? This
> would make the epics-pcas-dev package unnecessary for 3.15+, too.
Konrad,
thanks for your efforts!
I also stumbled over the CAS include issue. Have a look at
   http://www.aps.anl.gov/epics/core-talk/2011/msg00065.php
to see the (still current) state of discussion.
Michael was helping by adding the epics-pcas-dev package as a quick
workaround until a final fix is available.
Cheers,
~Ralph
cagateway: CAS include issue Martin Konrad
cagateway: building with CMake, creating Debian/RPM packages Martin Konrad
Prev: cagateway: building with CMake, creating Debian/RPM packages Martin Konrad
Next: PSI C# library 1.2.0.0 Mogamad Amien Crombie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: cagateway: CAS include issue Martin Konrad
