1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: FW: windows-x64 problem
To: <[email protected]>
Cc: [email protected]
Date: Thu, 20 Oct 2011 17:28:01 -0500
Jeff,
I'm having a problem with DLLs on 64-bit Windows.  I am building a DLL that will be called from IDL (similar to calling from Visual Basic).  The DLL must have undecorated names for the entry points.  For 32-bit Windows we have been using a .DEF file to achieve this, and it works fine.  However, when we build for 64-bit Windows the names are undecorated by default, and I get a whole bunch of warnings if I use the .DEF file.
This is in the EPICS extension ezcaIDL.  If I delete the .DEF file then 64-bit Windows builds fine, but the 32-bit build has decorated names and so does not work.
Have you seen this problem. Are we doing something wrong?
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref /release /MACHINE:X64 /manifest /implib:ezcaIDL
.lib /out:ezcaIDL.dll /def:../ezcaIDL.def ezcaIDL.obj ..\\..\\..\\lib\\windows-x64\\ezca.lib ..\\..\\..\\lib\\windows-x64\\EzcaScan.lib H:\\epics\\base-3.14.12.1\\lib\\windows-x64\\ca.lib H:\\epics\\base-3.14.12.1\\lib\\windows-x64\\Com.lib ws2_32.lib advapi32.lib user32.lib
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Zero' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Clear' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Add' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Get' specified multiple times; using first specification
Sent: Thu 10/20/2011 5:15 PM
To: Janet Anderson
Subject: RE: windows-x64 problem
Hi Janet,
No, IDL does not work with the decorated names.  I built with no .DEF file.  That creates undecorated names on 64-bit, but decorated names on 32-bit.
Now I assign the environment variable to the 64-bit DLL and run the 64-bit version of IDL.  It works.
H:\epics\extensions_devel\src\ezcaIDL>set EZCA_IDL_SHARE=H:\epics\extensions_devel\bin\windows-x64\ezcaIDL.dll
H:\epics\extensions_devel\src\ezcaIDL>"c:\Program Files\ITT\IDL\IDL81\bin\bin.x86_64\idl.exe"
IDL Version 8.1, Microsoft Windows (Win32 x86_64 m64). (c) 2011, ITT Visual Information Solutions
IDL> t = caget('13BMD:m1', v)
IDL> print, t, v
           0      -8.4500098
Now I assign the environment variable to the 32-bit DLL and run the 32-bit version of IDL. It fails.
H:\epics\extensions_devel\src\ezcaIDL>set EZCA_IDL_SHARE=H:\epics\extensions_devel\bin\win32-x86\ezcaIDL.dll
H:\epics\extensions_devel\src\ezcaIDL>"c:\Program Files\ITT\IDL\IDL81\bin\bin.x86_64\idl.exe" -32
IDL Version 8.1, Microsoft Windows (Win32 x86 m32). (c) 2011, ITT Visual Information Solutions
% CALL_EXTERNAL: Error loading sharable executable.
                 Symbol: ezcaIDLGetCountAndType, File = H:\epics\extensions_devel\bin\win32-x86\ezcaIDL.dll
                 The specified procedure could not be found.
% Execution halted at: CALL_EZCA         113 H:\idl_user\epics\ezcaIDL.pro
%                      CAGETCOUNTANDTYPE  324 H:\idl_user\epics\ezcaIDL.pro
%                      CAGET             479 H:\idl_user\epics\ezcaIDL.pro
%                      CALL_EZCA         111 H:\idl_user\epics\ezcaIDL.pro
%                      CAINIT           1666 H:\idl_user\epics\ezcaIDL.pro
%                      $MAIN$
So the linker must produce the undecorated names for IDL to be able to find them.  That is why we used the .DEF file originally.  What's strange is that the for 64-bits it creates undecorated names by default, and generates warnings if we supply a .DEF file.
Sent: Thu 10/20/2011 1:33 PM
To: Mark Rivers
Subject: Re: windows-x64 problem
Hi Mark,
I think it might be ok for the x86 names to be decorated and the x64 name to have no decoration.
Does the x86 dll work when created with NO def file? I thinks that the x86 decorations are different than x64decorations.
Janet
Mark Rivers wrote:
	Hi Janet,
	Something is strange here.  I only get the warnings when I build for windows-x64, not when I build for win32-x86.
	I then tried renaming ezcaIDL.def as you suggested.  The eliminates the warnings.  On windows-x64 the ezcaIDL.dll file looks fine, it is exporting the correct symbols:
	H:\epics\extensions_devel\src\ezcaIDL>dumpbin /exports ..\..\bin\windows-x64\ezcaIDL.dll
	Microsoft (R) COFF/PE Dumper Version 9.00.21022.08
	Copyright (C) Microsoft Corporation.  All rights reserved.
	Dump of file ..\..\bin\windows-x64\ezcaIDL.dll
	File Type: DLL
	  Section contains the following exports for ezcaIDL.dll
	    00000000 characteristics
	    4EA05FBD time date stamp Thu Oct 20 12:51:57 2011
	        0.00 version
	           1 ordinal base
	          53 number of functions
	          53 number of names
	    ordinal hint RVA      name
	          1    0 00060A50 EzcaAddMonitorArray
	          2    1 00060760 EzcaCheckMonitorArray
	          3    2 000608E0 EzcaClearMonitorArray
	          4    3 0005FFC0 EzcaDebug
	          5    4 00060D70 EzcaGetArrayEventValues
	          6    5 00060DF0 EzcaGetArrayTypeCount
	          7    6 00060EB0 EzcaGetArrayValues
	          8    7 00060F80 EzcaGetError
	          9    8 00060820 EzcaGetMonitorArray
	         10    9 0005FFA0 EzcaInit
	         11    A 000600F0 EzcaMonitorQueue_Add
	         12    B 00060090 EzcaMonitorQueue_Clear
	         13    C 00060160 EzcaMonitorQueue_Get
	         14    D 00060030 EzcaMonitorQueue_Zero
	         15    E 00061130 EzcaMonitorScan_Add
	         16    F 00060B70 EzcaMonitorScan_Clear
	         17   10 00060B40 EzcaMonitorScan_Get
	         18   11 00060AE0 EzcaMonitorScan_Zero
	         19   12 00060260 EzcaPendEvent
	         20   13 00060BD0 EzcaPutArrayEventValues
	         21   14 00060CA0 EzcaPutArrayValues
	         22   15 00060190 EzcaSearchList
	         23   16 0005FF80 EzcaSetPendTime
	         24   17 00061090 EzcaTimeStamp
	         25   18 00060000 EzcaVersion
	         26   19 00060290 ezcaIDLAutoErrorMessageOff
	         27   1A 000602B0 ezcaIDLAutoErrorMessageOn
	         28   1B 000610B0 ezcaIDLClearMonitor
	         29   1C 00060310 ezcaIDLDebugOff
	         30   1D 00060330 ezcaIDLDebugOn
	         31   1E 00060350 ezcaIDLEndGroup
	         32   1F 00060480 ezcaIDLEndGroupWithReport
	         33   20 00060730 ezcaIDLGet
	         34   21 00061110 ezcaIDLGetControlLimits
	         35   22 00060590 ezcaIDLGetCountAndType
	         36   23 00060370 ezcaIDLGetEnumStrings
	         37   24 00060650 ezcaIDLGetErrorString
	         38   25 000610F0 ezcaIDLGetGraphicLimits
	         39   26 00060710 ezcaIDLGetPrecision
	         40   27 00060500 ezcaIDLGetRetryCount
	         41   28 000606F0 ezcaIDLGetStatus
	         42   29 00060520 ezcaIDLGetTimeout
	         43   2A 000606D0 ezcaIDLGetUnits
	         44   2B 00060570 ezcaIDLNewMonitorValue
	         45   2C 000606B0 ezcaIDLPerror
	         46   2D 00060620 ezcaIDLPut
	         47   2E 000605F0 ezcaIDLPutOldCa
	         48   2F 000610D0 ezcaIDLSetMonitor
	         49   30 00060540 ezcaIDLSetRetryCount
	         50   31 00060550 ezcaIDLSetTimeout
	         51   32 00060360 ezcaIDLStartGroup
	         52   33 000602D0 ezcaIDLTraceOff
	         53   34 000602F0 ezcaIDLTraceOn
	  Summary
	       17000 .data
	        8000 .pdata
	       22000 .rdata
	        2000 .reloc
	        1000 .rsrc
	       6E000 .text
	Note the exported names are undecorated.  However, the win32-x86 version is no good, the names are decorated.  These were built on the same machine, same compiler, just changing the EPICS_HOST_ARCH and which vcvarsall.bat file was invoked.  So it looks like the .def file is needed on 32-bit, but should not be used on 64-bit.  Why?
	H:\epics\extensions_devel\src\ezcaIDL>dumpbin/exports ..\..\bin\win32-x86\ezcaIDL.dll
	Dump of file ..\..\bin\win32-x86\ezcaIDL.dll
	File Type: DLL
	    4EA05FF7 time date stamp Thu Oct 20 12:52:55 2011
	        0.00 version
	           1 ordinal base
	          53 number of names
	          1    0 00049660 _EzcaAddMonitorArray@8 <mailto:_EzcaAddMonitorArray@8> <mailto:_EzcaAddMonitorArray@8>
	          2    1 00049590 _EzcaCheckMonitorArray@8 <mailto:_EzcaCheckMonitorArray@8> <mailto:_EzcaCheckMonitorArray@8>
	          3    2 00049620 _EzcaClearMonitorArray@8 <mailto:_EzcaClearMonitorArray@8> <mailto:_EzcaClearMonitorArray@8>
	          4    3 00048F60 _EzcaDebug@8 <mailto:_EzcaDebug@8> <mailto:_EzcaDebug@8>
	          5    4 000497E0 _EzcaGetArrayEventValues@8 <mailto:_EzcaGetArrayEventValues@8> <mailto:_EzcaGetArrayEventValues@8>
	          6    5 00049830 _EzcaGetArrayTypeCount@8 <mailto:_EzcaGetArrayTypeCount@8> <mailto:_EzcaGetArrayTypeCount@8>
	          7    6 00049880 _EzcaGetArrayValues@8 <mailto:_EzcaGetArrayValues@8> <mailto:_EzcaGetArrayValues@8>
	          8    7 000498D0 _EzcaGetError@8 <mailto:_EzcaGetError@8> <mailto:_EzcaGetError@8>
	          9    8 000495E0 _EzcaGetMonitorArray@8 <mailto:_EzcaGetMonitorArray@8> <mailto:_EzcaGetMonitorArray@8>
	         10    9 00048F40 _EzcaInit@8 <mailto:_EzcaInit@8> <mailto:_EzcaInit@8>
	         11    A 00049040 _EzcaMonitorQueue_Add@8 <mailto:_EzcaMonitorQueue_Add@8> <mailto:_EzcaMonitorQueue_Add@8>
	         12    B 00049000 _EzcaMonitorQueue_Clear@8 <mailto:_EzcaMonitorQueue_Clear@8> <mailto:_EzcaMonitorQueue_Clear@8>
	         13    C 00049090 _EzcaMonitorQueue_Get@8 <mailto:_EzcaMonitorQueue_Get@8> <mailto:_EzcaMonitorQueue_Get@8>
	         14    D 00048FC0 _EzcaMonitorQueue_Zero@8 <mailto:_EzcaMonitorQueue_Zero@8> <mailto:_EzcaMonitorQueue_Zero@8>
	         15    E 000499B0 _EzcaMonitorScan_Add@8 <mailto:_EzcaMonitorScan_Add@8> <mailto:_EzcaMonitorScan_Add@8>
	         16    F 00049700 _EzcaMonitorScan_Clear@8 <mailto:_EzcaMonitorScan_Clear@8> <mailto:_EzcaMonitorScan_Clear@8>
	         17   10 000496E0 _EzcaMonitorScan_Get@8 <mailto:_EzcaMonitorScan_Get@8> <mailto:_EzcaMonitorScan_Get@8>
	         18   11 000496A0 _EzcaMonitorScan_Zero@8 <mailto:_EzcaMonitorScan_Zero@8> <mailto:_EzcaMonitorScan_Zero@8>
	         19   12 00049160 _EzcaPendEvent@8 <mailto:_EzcaPendEvent@8> <mailto:_EzcaPendEvent@8>
	         20   13 00049740 _EzcaPutArrayEventValues@8 <mailto:_EzcaPutArrayEventValues@8> <mailto:_EzcaPutArrayEventValues@8>
	         21   14 00049790 _EzcaPutArrayValues@8 <mailto:_EzcaPutArrayValues@8> <mailto:_EzcaPutArrayValues@8>
	         22   15 000490C0 _EzcaSearchList@8 <mailto:_EzcaSearchList@8> <mailto:_EzcaSearchList@8>
	         23   16 00048F20 _EzcaSetPendTime@8 <mailto:_EzcaSetPendTime@8> <mailto:_EzcaSetPendTime@8>
	         24   17 00049910 _EzcaTimeStamp@8 <mailto:_EzcaTimeStamp@8> <mailto:_EzcaTimeStamp@8>
	         25   18 00048F90 _EzcaVersion@8 <mailto:_EzcaVersion@8> <mailto:_EzcaVersion@8>
	         26   19 00049180 _ezcaIDLAutoErrorMessageOff@8 <mailto:_ezcaIDLAutoErrorMessageOff@8> <mailto:_ezcaIDLAutoErrorMessageOff@8>
	         27   1A 00049190 _ezcaIDLAutoErrorMessageOn@8 <mailto:_ezcaIDLAutoErrorMessageOn@8> <mailto:_ezcaIDLAutoErrorMessageOn@8>
	         28   1B 00049930 _ezcaIDLClearMonitor@8 <mailto:_ezcaIDLClearMonitor@8> <mailto:_ezcaIDLClearMonitor@8>
	         29   1C 000491C0 _ezcaIDLDebugOff@8 <mailto:_ezcaIDLDebugOff@8> <mailto:_ezcaIDLDebugOff@8>
	         30   1D 000491D0 _ezcaIDLDebugOn@8 <mailto:_ezcaIDLDebugOn@8> <mailto:_ezcaIDLDebugOn@8>
	         31   1E 000491E0 _ezcaIDLEndGroup@8 <mailto:_ezcaIDLEndGroup@8> <mailto:_ezcaIDLEndGroup@8>
	         32   1F 00049300 _ezcaIDLEndGroupWithReport@8 <mailto:_ezcaIDLEndGroupWithReport@8> <mailto:_ezcaIDLEndGroupWithReport@8>
	         33   20 00049560 _ezcaIDLGet@8 <mailto:_ezcaIDLGet@8> <mailto:_ezcaIDLGet@8>
	         34   21 00049990 _ezcaIDLGetControlLimits@8 <mailto:_ezcaIDLGetControlLimits@8> <mailto:_ezcaIDLGetControlLimits@8>
	         35   22 00049400 _ezcaIDLGetCountAndType@8 <mailto:_ezcaIDLGetCountAndType@8> <mailto:_ezcaIDLGetCountAndType@8>
	         36   23 00049210 _ezcaIDLGetEnumStrings@8 <mailto:_ezcaIDLGetEnumStrings@8> <mailto:_ezcaIDLGetEnumStrings@8>
	         37   24 000494A0 _ezcaIDLGetErrorString@8 <mailto:_ezcaIDLGetErrorString@8> <mailto:_ezcaIDLGetErrorString@8>
	         38   25 00049970 _ezcaIDLGetGraphicLimits@8 <mailto:_ezcaIDLGetGraphicLimits@8> <mailto:_ezcaIDLGetGraphicLimits@8>
	         39   26 00049540 _ezcaIDLGetPrecision@8 <mailto:_ezcaIDLGetPrecision@8> <mailto:_ezcaIDLGetPrecision@8>
	         40   27 00049360 _ezcaIDLGetRetryCount@8 <mailto:_ezcaIDLGetRetryCount@8> <mailto:_ezcaIDLGetRetryCount@8>
	         41   28 00049520 _ezcaIDLGetStatus@8 <mailto:_ezcaIDLGetStatus@8> <mailto:_ezcaIDLGetStatus@8>
	         42   29 00049380 _ezcaIDLGetTimeout@8 <mailto:_ezcaIDLGetTimeout@8> <mailto:_ezcaIDLGetTimeout@8>
	         43   2A 00049500 _ezcaIDLGetUnits@8 <mailto:_ezcaIDLGetUnits@8> <mailto:_ezcaIDLGetUnits@8>
	         44   2B 000493E0 _ezcaIDLNewMonitorValue@8 <mailto:_ezcaIDLNewMonitorValue@8> <mailto:_ezcaIDLNewMonitorValue@8>
	         45   2C 000494E0 _ezcaIDLPerror@8 <mailto:_ezcaIDLPerror@8> <mailto:_ezcaIDLPerror@8>
	         46   2D 00049470 _ezcaIDLPut@8 <mailto:_ezcaIDLPut@8> <mailto:_ezcaIDLPut@8>
	         47   2E 00049440 _ezcaIDLPutOldCa@8 <mailto:_ezcaIDLPutOldCa@8> <mailto:_ezcaIDLPutOldCa@8>
	         48   2F 00049950 _ezcaIDLSetMonitor@8 <mailto:_ezcaIDLSetMonitor@8> <mailto:_ezcaIDLSetMonitor@8>
	         49   30 000493A0 _ezcaIDLSetRetryCount@8 <mailto:_ezcaIDLSetRetryCount@8> <mailto:_ezcaIDLSetRetryCount@8>
	         50   31 000493C0 _ezcaIDLSetTimeout@8 <mailto:_ezcaIDLSetTimeout@8> <mailto:_ezcaIDLSetTimeout@8>
	         51   32 00049200 _ezcaIDLStartGroup@8 <mailto:_ezcaIDLStartGroup@8> <mailto:_ezcaIDLStartGroup@8>
	         52   33 000491A0 _ezcaIDLTraceOff@8 <mailto:_ezcaIDLTraceOff@8> <mailto:_ezcaIDLTraceOff@8>
	         53   34 000491B0 _ezcaIDLTraceOn@8 <mailto:_ezcaIDLTraceOn@8> <mailto:_ezcaIDLTraceOn@8>
	  Summary
	       13000 .data
	       14000 .rdata
	        8000 .reloc
	        1000 .rsrc
	Sent: Thu 10/20/2011 10:29 AM
	To: Mark Rivers
	Hi Mark,
	I think you may not need the ezcaIDL.def file.  Try renaming it and
	rebuilding. If that does not work, try removing the the EXPORTS line and
	all lines after it.
	Janet
	Mark Rivers wrote:
		It works, producing an ezcaIDL.dll file that I can use from IDL, but I don't like those warnings.  Do you know how to get rid of them?
		Sent: Wed 10/19/2011 4:40 PM
		To: 'Janet Anderson'
		Subject: windows-x64 problem
RE: windows-x64 problem Jeff Hill
Prev: RE: PVManager ReadOnly Check Dalesio, Leo
Next: RE: PVManager ReadOnly Check james.rowland
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: windows-x64 problem Jeff Hill
