1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: seq lib load error (vxworks)
To: <[email protected]>
Date: Fri, 21 Oct 2011 12:06:55 +0200
Title: seq lib load error (vxworks)
Hi- I've built a single *Lib.munch from two separate *.st files, and get this error at load time.
The seqs run fine after this, but I can't use it in a boot script because it will abort the boot.  A
lib built from a single *.st doesn't have this problem.
        Loading bin/seqMagCycleLib.munch
        Undefined symbol: pvar_func_Registrar (binding 1 type 0)
        Loading seqMagCycle library failed: S_objLib_OBJ_UNAVAILABLE
        Aborting startup stript.
        value = -1 = 0xffffffff
Any ideas?
thanks
Mike
Re: seq lib load error (vxworks) Andrew Johnson
Prev: RE: PVManager ReadOnly Check james.rowland
Next: Logging change of state for binary input in Message History of CSS ZYCHLA Emmanuel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: windows-x64 problem Mark Rivers
Next: Re: seq lib load error (vxworks) Andrew Johnson
