1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: epicsQt plugin build errors
To: "tech-talk" <[email protected]>
Date: Tue, 1 Nov 2011 16:03:52 +0800
Hello,
I downloaded epicsqt-1.1.6 and when I tried to build EPICS-Qt Pluginon Windows xp, the following errors occured:
./debug\CaObject.o:D:\Qt\Qt EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:88: undefined reference to `epicsEventCreate'
./debug\CaObject.o:D:\Qt\Qt EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:89: undefined reference to `epicsMutexOsiCreate'
./debug\CaObject.o:D:\Qt\Qt EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:104: undefined reference to `epicsMutexDestroy'
./debug\CaObject.o:D:\Qt\Qt EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:105: undefined reference to `epicsEventDestroy'
./debug\CaObject.o:D:\Qt\Qt EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:478: undefined reference to `dbr_size'
./debug\CaObject.o:D:\Qt\Qt EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:478: undefined reference to `dbr_value_size'
./debug\CaObject.o:D:\Qt\Qt EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:479: undefined reference to `ca_name'
collect2: ld returned 1 exit status
mingw32-make[1]: *** [debug\QCaPlugin.dll] Error 1
mingw32-make: *** [debug] Error 2
The process "C:/Qt/2010.04/mingw/bin/mingw32-make.exe" exited with code %2.
Error while building project plugins (target: Desktop)
When executing build step 'Make'
In the manual "EPICSQt Developers Guide", it is said that undefined references which usually indicate issues with PATH settings. The environment variable for EPICS in my machine setted as follows:
EPICS_BASE=C:\EPICS\base-3.14.8.2
EPICS_HOST_ARCH=win32-x86
And in PATH I added "C:\EPICS\base-3.14.8.2\bin\win32-x86" .
Anything else need to do?
Thank you!
Zhang Yuliang
Re: epicsQt plugin build errors Martin Konrad
Prev: last-minute ad-hoc tour in Hawaii? S. Stein
Next: RE: Sequence monitor not getting callback Zelazny, Michael Stanley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: epicsQt plugin build errors Martin Konrad
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
