Am Donnerstag, 3. November 2011, um 22:40:55 schrieb Andrew Johnson:
> On 2011-11-03 Martin Konrad wrote:
> > Please make sure that you have something like
> > LIBS += -L$$(EPICS_BASE)/lib/$$(EPICS_HOST_ARCH) \
> > -lca \
> > -lCom \
> > -L$$(QCAFRAMEWORK)/qwt-5.2.1/lib \
> > -lqwt
> It's possible that your link order might be a problem, make sure that you
> link against the ca and Com libraries *after* linking any libraries that
> calls them. In the above case I would suggest moving the -lca and -lCom
> options after the -lqwt.
A quick and dirty method to check that w/o much experimentation is to simply
repeat the whole bunch of -l<libname> options i.e. write
-lca -lCom -lqwt -lca -lCom -lqwt
If that works ythen ou know what causes the problem and you can then try to
minimize again by finding the correct order... but note that in case two or
more of the libraries you need have circular dependencies you might actually
/have/ to repeat some of them on the command line.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Re: epicsQt plugin build errors Martin Konrad
- Re: epicsQt plugin build errors Andrew Johnson
Re: Asyn or StreamDevice Error Messages: vxi11 clientIoCall errno Permission denied clnt_stat 5 Benjamin Franksen
Re: reading large data arrays over slow networks Peter Jemian
<2011>
2025
Re: epicsQt plugin build errors 张玉亮
<2011>
2025
