1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: reading large data arrays over slow networks
To: Jeff Hill <[email protected]>
Date: Fri, 4 Nov 2011 09:10:23 -0500
Tim, Jeff, Andrew,
On Thu, Nov 3, 2011 at 4:08 PM, Jeff Hill <[email protected]> wrote:
> Hi Matt,
> In a single threaded (non-preemptive callback) client no CA activity can
> occur (i.e. processing network packets and or calling callbacks) unless your
> single thread is executing in the CA library. The ca_pend_event call is
> purely a mechanism for spending some time, the amount of time being
> specified by its sole argument, in the library. The ca_pend_event call is
> not used in any way for synchronizing ca_array_get (or channel
> connectivity).
> In contrast, ca_pend_io will synchronize completion of all outstanding
> ca_array_get requests issued since the beginning of the ca context, or the
> previous call to ca_pend_io, whichever is later. In practice, what this
> implies is that ca_pend_io is a one-time synchronization. If it returns
> ECA_TIMEOUT this implies that any incomplete CA get requests are effectively
> canceled. The library will _not_ allow your variable, specified to ca get,
> to be modified unexpectedly far in the future after ca_pend_io returns if
> the network is slow. That could be result in a disaster, for example, if you
> are using a stack automatic variable.
>> That is, how do I know how long to wait in ca_pend_event() and
>> ca_pend_io()?
> It's actually quite difficult to write a program that is generic in a wide
> range of networking environments if there are any short timeouts which are
> hardcoded. In practice, network generic programs with complex state
> transitions typically use CA callbacks.
>> leaves the data at pvalue incorrect (all zeros).  Trying to access
>> this data from python, I can get python to segfault for large enough
>> data (say, 4.2M ints).  I'm not sure I fully understand why python is
>> crashing -- the segfault happens well after ca_array_get() returns,
>> but can happen in ca_pend_event() a short time later.  If I save but
>> don't try to access the data in pvalue, or wait "long enough", it
>> seems I never have a crash.
> I suspect that python, or the ca python interface library, isn't happy if
> its data is being modified by an outside thread (i.e. a ca client library
> auxiliary thread) precisely at the same time that its being read. It's
> probably a good idea not to touch the data until ca_pend_io synchronized, or
> alternatively use a callback.
>> Is there a way to tell if pend_event() or pend_io() have timed out
> They return ECA_TIMEOUT
>> or if there are events that are pending?
> The ca_pend_io call returns ECA_TIMEOUT if it timed out before all of the
> get requests completed, and otherwise ECA_NORMAL if they did complete. There
> is also a mechanism for determining at any given instant if the ca_client
> library has outstanding labor (network activity) which needs to be dealt
> with. I can provide more details on that if you are interested.
> If you need to know precisely which get requests failed out of many then
> it's probably best to use a callback mechanism.
> Jeff
Thanks, that's all very helpful -- I think I had a fundamental
misunderstanding of ca_pend_io().
The python crashes are easy enough to avoid if I see that ca_pend_io()
times out, but that still leaves open the possibility of the data not
being properly written and is reacting to a problem (allocating
memory, passing it to ca_array_get(), and then having python garbage
collect it without telling CA  that this memory location has gone
away) that should be avoided.
Using ca_array_get_callback() definitely looks like the right
solution, and works well in an initial test. I'll switch to that
approach.
--Matt
reading large data arrays over slow networks Matt Newville
RE: reading large data arrays over slow networks Jeff Hill
Prev: RE: epicsQt plugin build errors Andrew Rhyder
Next: mca R7-1 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: reading large data arrays over slow networks Jeff Hill
Next: Re: reading large data arrays over slow networks Andrew Johnson
