1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: quadEM R2-6
To: <[email protected]>, <[email protected]>
Date: Fri, 4 Nov 2011 11:52:03 -0500
Folks,
Release R2-6 of the synApps quadEM module is now available.  This is from the release notes at http://cars9.uchicago.edu/software/epics/quadEMReleaseNotes.html
- Added support for the remote reboot capability of the electrometer. This makes initialization much simpler and more robust, since it can be done with software commands rather than power-cycling and toggling switches. It is only supported on newer electrometer firmware, but does not cause ill effects when sent to older electrometers. Added a Reboot record to the database, and modified the Initialize seq record to process the Reboot record as the first thing it does.
- Added an additional optional parameter to initQuadEM. This is the drvInfo field for the ipUnidig module. Previously the driver hardcoded pasynUser->reason=0 when using the asynUInt32Digital interface. Now it uses drvUser->create, which is the correct way to do it.
- Created new documentation file, http://cars.uchicago.edu/software/epics/quadEMDOC.html.
This is the home page:
http://cars.uchicago.edu/software/epics/quadEM.html
This is the latest tar file:
http://cars.uchicago.edu/software/pub/quadEMR2-6.tgz
Cheers,
Prev: ipUnidig R2-9 Mark Rivers
Next: dxp R3-1 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
