Hi Peng,
> prosilica:writeFloat64: error, status=18 function=51, name=ACQ_PERIOD, value=0.040000
That message can appear on startup because at iocInit it is setting an AcquirePeriod that is inconsistent with the AcquireTime. It depends on the order in save/restore. I should fix it, but it is just a warning, and is not serious at all, so don't worry about it.
> Matlab automatically shut off. Did anyone know why?
Did you set EPICS_CA_MAX_ARRAY_BYTES to a large enough value on both the client and server computers? I have never used Matlab, but I seem to recall hearing that the Channel Access interface only supports reading arrays as doubles (64-bit floating points). If so, you need to multiply EPICS_CA_MAX_ARRAY_BYTES by 8 over what you would normally use, since the Prosilica is normally sending 8-bit data. If that is true it makes Matlab quite inefficient for video data. IDL and ImageJ may be better for imaging clients, since they support reading 8-bit arrays.
Sent: Wed 11/9/2011 5:31 AM
To: [email protected]
Subject: About the problem of areaDetector module's compiling and run
Dear
I met some problems. When I ran the areaDetector module, it appeared such mistakes.
13PS1:cam1:AcquirePeriod devAsynFloat64 process error
When I ran it again, this mistake was gone.Did someone come across the problem? How to solve it? Meanwhile there was other question. I used Matlab to read the PV(13PS1:image1:ArrayData). When I used the command that was "A = lcaGet('13PS1:image1:ArrayData');" , Matlab automatically shut off. Did anyone know why?
Thanks!
Best wishes
Peng
- About the problem of areaDetector module's compiling and run 的
PV in PCAS can not be archived by Channel Archiver Zhang Yuliang
<2011>
2025
RE: About the problem of areaDetector module's compiling and run Allison, Stephanie
<2011>
2025
