1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: documentation for stringout fields
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 18 Nov 2011 11:18:42 -0600
Andrew,
The MPST setting I needed was "Always".
Kevin
On 11/18/11 10:41 AM, Andrew Johnson wrote:
> Hi Kevin,
> On 2011-11-17 you wrote:
>> I'm using a stringout record and I noticed that it only writes the
>> string to the PV specified in the OUT field when the string changes.  I
>> was hoping to change this.  I took a look at the stringout fields and
>> noticed two fields that are set to "On Change":
> Looking at the source code the record does call the device support's write
> routine every time it processes.  Your dbpr output which I snipped showed that
> you're using Soft Channel device support but the OUT field is empty, so it's
> not actually writing the string value anywhere.  However it looks like you
> don't really need it to, and you're really asking about it posting channel
> access monitors instead...
>> Unfortunately I can't find documentation for the APST and MPST fields.
>> I've searched tech-talk, as well as this page (and fields common to all
>> & many record types):
>> http://www.aps.anl.gov/epics/wiki/index.php/RRM_3-14_String_Output
>> Is there a record documentation location I've missed?  What do the APST
>> and MPST fields do?
> They control when the record posts CA monitors (MPST => value monitors, APST
> => archive monitors) on the VAL field.  For your needs I think you just want
> to set the MPST field to "Every time" (or whatever the choice string actually
> is).
> The APST and MPST fields exist in the aai, aao, stringin and waveform records
> too, but it looks like you're right that no documentation exists to describe
> them.  I'm copying this reply to tech-talk in the hope that someone who has a
> wiki account will be willing to add something about them to the
> http://www.aps.anl.gov/epics/wiki/index.php/RRM_3-14_Common "Fields common to
> many record types" and to the pages for those 5 record types.
> - Andrew
Re: documentation for stringout fields Andrew Johnson
Prev: Re: documentation for stringout fields Andrew Johnson
Next: Re: EPICS stackoverflow site J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: vxWorks NTP Sync graham.cox
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
