Hi Andrew,
I think that's a great idea. A warning message would be a big help for those not yet familiar with the building system.
Luciano
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Thursday, December 01, 2011 15:44
To: [email protected]
Subject: Re: Asyn: "devAsynInt32::initCommon Link must be INST_IO"
Hi Luciano,
On 2011-12-01 Piccoli, Luciano wrote:
> This problem would have easily been caught if the configure/Makefile had
> the CHECK_RELEASE=YES. It was set to NO in the module I used as a starting
> point.
CHECK_RELEASE also has a WARN setting which I would always recommend using
instead of NO if you need to override an inconsistency (and you understand
what you're doing). Maybe setting it to NO should print a warning?
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- Asyn: "devAsynInt32::initCommon Link must be INST_IO" Piccoli, Luciano
- RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Piccoli, Luciano
- Re: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Andrew Johnson
Re: EPICS Base 3.14.12.2-rc1 available for testing Dirk Zimoch
<2011>
2025
<2011>
2025
