1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: [help] EPICS build no good
To: Pavel Masloff <[email protected]>
Cc: [email protected]
Date: Mon, 05 Dec 2011 10:33:14 -0600
Check everything.  Sometimes you have to start again from scratch.
For example, are you positive you are using the compilers from the mingw installation? All I see in the output is g++. This might explain why -fpermissive did not work.
Geoff
On 12/5/2011 10:16 AM, Pavel Masloff wrote:
it had been set so prior
2011/12/5 Janet Anderson <[email protected] <mailto:[email protected]>>
    __
    Looks like the definitions of CC and CCC  are incorrect.  Try
    setting CC=gcc and CCC=g++ in
    configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw.
    Janet
    Hey Mark,
    I don't know where this error comes from (the single quotes). I
    thought running softIoc.exe is a simple way to check the
    installation.
    No, your suggestions didn't work (sorry, partly in Russian, I can
    translate if you need):
    "Installing generic include file ../../../include/tsDefs.h"
    windres -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32
    -I../../../src/libCom/osi/os/posix
    -I../../../src/libCom/osi/os/default -I..
    -I../../../src/libCom/bucketLib -I../../../src/libCom/ring
    -I../../../src/libCom/calc -I../../../src/libCom/cvtFast
    -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
    -I../../../src/libCom/dbmf -I../../../
    src/libCom/ellLib -I../../../src/libCom/env
    -I../../../src/libCom/error -I../../../src/libCom/fdmgr
    -I../../../src/libCom/freeList -I../../../src/libCom/gpHash
    -I../../../src/libCom/iocsh -I../../../src/libCom/logClient
    -I../../../src/libCom/macLib -I../../../src/libCom/misc
    -I../../../src/libCom/osi -I../../../src/libCom/taskwd
    -I../../../src/libCom/timer -I../../../src/libCom/tsDefs
    -I../../../include/os/WIN32 -I../../../include        ../Com.rc
    Com.coff
    g++ -c             -D_MINGW     -O3   -Wall     -fpermissive
    -m32    -D_DLL   -MMD -I. -I../O.Common -I.
    -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
    -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I..
    -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../
    -I../../../inclu
    ../../../src/libCom/bucketLib/bucketLib.c
    ../../../src/libCom/bucketLib/bucketLib.c: В функции <ITEM**
    bucketStringCompare(ITEM**, const void*)>:
    ../../../src/libCom/bucketLib/bucketLib.c:125:21: предупреждение:
    некорректное преобразование из <const void*> в <const
    char*> [-fpermissive]
    ../../../src/libCom/bucketLib/bucketLib.c: В функции <BUCKETID
    bucketUnsignedHash(BUCKET*, const void*)>:
    ../../../src/libCom/bucketLib/bucketLib.c:147:25: предупреждение:
    unsigned int*> [-fpermissive]
    bucketStringHash(BUCKET*, const void*)>:
    ../../../src/libCom/bucketLib/bucketLib.c:197:21: предупреждение:
    -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src
    /libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix
    -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/
    bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc
    -I../../../src/libCom/cvtFast -I../../../src/libCom/cppS
    td -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf
    -I../../../src/libCom/ellLib -I../../../src/libCom/env
    -I../../../inclu
    ../../../src/libCom/ring/epicsRingPointer.cpp
    -I../../../inclu
    ../../../src/libCom/ring/epicsRingBytes.c
    ../../../src/libCom/ring/epicsRingBytes.c: В функции <void*
    epicsRingBytesCreate(int)>:
    ../../../src/libCom/ring/epicsRingBytes.c:42:78: предупреждение:
    некорректное преобразование из <void*> в <ringPvt* {aka
     ringPvt*}> [-fpermissive]
    ../../../src/libCom/ring/epicsRingBytes.c:44:63: предупреждение:
    некорректное преобразование из <void*> в <volatile char
    *> [-fpermissive]
    -I../../../inclu
    ../../../src/libCom/calc/postfix.c
    ../../../src/libCom/calc/postfix.c:129:1: предупреждение:
    deprecated conversion from string constant to <char*> [-Wwrite
    -strings]
    ../../../src/libCom/calc/postfix.c:163:1: предупреждение:
    -strings]
    ../../../src/libCom/calc/postfix.c: В функции <long int
    postfix(const char*, char*, short int*)>:
    ../../../src/libCom/calc/postfix.c:272:42: предупреждение:
    некорректное преобразование из <int> в <rpn_opcode> [-fpermis
    sive]
    -I../../../inclu
    ../../../src/libCom/calc/calcPerform.c
    -I../../../inclu
    ../../../src/libCom/cvtFast/cvtFast.c
    -I../../../inclu
    ../../../src/libCom/cxxTemplates/resourceLib.cpp
    ../../../src/libCom/cxxTemplates/epicsOnce.cpp
    In file included from
    ../../../src/libCom/cxxTemplates/epicsOnce.cpp:29:0:
    ../../../src/libCom/cxxTemplates/epicsSingleton.h:37:5: ошибка:
    <size_t> не является именем типа
    ../../../src/libCom/cxxTemplates/epicsSingleton.h: In constructor
    <SingletonUntyped::SingletonUntyped()>:
    ../../../src/libCom/cxxTemplates/epicsSingleton.h:162:23: ошибка:
    в классе <SingletonUntyped> не имеет поля с именем <_refCount>
    mingw32-make[3]: *** [epicsOnce.o] Error 1
    mingw32-make[3]: Leaving directory
    `C:/epics/base/bin/win32-x86-mingw/src/libCom/O.win32-x86-mingw'
    mingw32-make[2]: *** [install.win32-x86-mingw] Error 2
    mingw32-make[2]: Leaving directory
    `C:/epics/base/bin/win32-x86-mingw/src/libCom'
    mingw32-make[1]: *** [libCom.install] Error 2
    mingw32-make[1]: Leaving directory
    `C:/epics/base/bin/win32-x86-mingw/src'
    mingw32-make: *** [src.install] Error 2
    mingw32-make: Leaving directory `C:/epics/base/bin/win32-x86-mingw'
    On Sun, Dec 4, 2011 at 11:46 PM, Mark Rivers
    <[email protected] <mailto:[email protected]>> wrote:
        I don't know about the problem with softIoc.  Where is it
        getting those single quotes?
        Did you try my suggestion of -fpermissive when building with
        MinGW?  I think it should have at least eliminated the error
        you reported.
        <mailto:[email protected]>]
        Sent: Sun 12/4/2011 1:48 PM
        To: Mark Rivers
        Cc: [email protected] <mailto:[email protected]>;
        Hey Mark,
        The base I am trying to build is 3.14.12.1.
        Mingw32-make didn't work. So i tried Microsoft Visual Studio
        2010 Express. The compilation ended successfully with a few
        warnings.
        However, when I try to run softIoc.exe, I see the following error:
        d:\>softIoc
        filename="..\dbLexRoutines.c" line number=243
        Invalid argument dbRead opening file
        'D:\baseR3.14.12.1\new'/dbd/softIoc.dbd
        Pavel
        On Sat, Dec 3, 2011 at 1:26 AM, Mark Rivers
        wrote:
               Hi Pavel,
               What version of base is this?
               I think you can avoid this error by adding this line to
        base/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
               USR_CFLAGS += -fpermissive
               USR_CXXFLAGS += -fpermissive
               But if this is the latest version of base then I think
        there is an error that should be fixed.
               Sent: Friday, December 02, 2011 4:13 PM
               To: Mark Rivers
        <mailto:[email protected]>; [email protected]
               Mark,
               I did what you'd proposed.
               This is what i get:
        -I../../../src/libCom/osi/os/posix -I../../../src/libC
               m/osi/os/default -I.. -I../../../src/libCom/bucketLib
        -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../
               rc/libCom/cvtFast -I../../../src/libCom/cppStd
        -I../../..
        -I../../../src/libC
        -I../../../src/libC
               I../../../src/libCom/tsDefs -I../../../include/os/WIN32
        -I../../../include        ../Com.rc Com.coff
               g++ -c             -D_MINGW     -O3   -Wall      -m32
         -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/
        -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd
        -I../../.
        -I../../../s
        -I../../../src/l
               I../../../include
               ../../../src/libCom/bucketLib/bucketLib.c: In function
        <ITEM** bucketStringCompare(ITEM**, const void*)>:
        error: incorrect transform from <const void*> to <const char*>
               -fpermissive]
               ../../../src/libCom/bucketLib/bucketLib.c: in function
        <BUCKETID bucketUnsignedHash(BUCKET*, const void*)>:
        error: incorrect transform from <const void*> to <const unsigne
        <BUCKETID bucketStringHash(BUCKET*, const void*)>:
               -fpermissive]
               mingw32-make[3]: *** [bucketLib.o] Error 1
               On Sat, Dec 3, 2011 at 12:45 AM, Mark Rivers
        wrote:
               Hi Pavel,
               I understand now.  I thought you were just using MinGW
        for gnumake.  But you want to use the gcc compiler as well.
               You have set the wrong value for EPICS_HOST_ARCH.  You
        have set it to win32-x86, which is the architecture that
        requires Visual Studio.
               You need to set the environment variable
        EPICS_HOST_ARCH to win32-x86-mingw.  That will use gcc.
               Sent: Friday, December 02, 2011 3:41 PM
               To: Mark Rivers; [email protected]
               Hi Mark,
               Do I really need MS Visual Studio?
               According to this
        (http://www.aps.anl.gov/epics/base/win32.phphttp://www.aps.anl.gov/epics/base/win32.php):
               Download and install a compiler:
               * Microsoft Visual C++ Express 2010, or
               * MinGW version of GCC
               * You can also use Microsoft's commercial C++
        development tools if you have them.
               I used MinGW. I see 'or' here.
               On Sat, Dec 3, 2011 at 12:27 AM, Mark Rivers
        wrote:
               Hi Pavel,
               I think the problem is that you have not set up your
        environment for Visual Studio.  Your PATH environment variable
        does not include the path to the Visual Studio compiler.  You
        need to execute the "vcvarsall.bat file that comes with Visual
        Studio.
               This is the batch file I use to set up EPICS builds for
        win32-x86.
               rem This file sets up for an EPICS win32-x86 build
               set EPICS_HOST_ARCH=win32-x86
               rem This is the location of "make"
               set PATH=C:\Program
        Files\GnuWin32\bin;C:\Perl\bin;H:\epics\base\bin\win32-x86;%PATH%
        "C:\Program Files\Microsoft Visual Studio
        9.0\VC\vcvarsall.bat" x86
        [mailto:[email protected]
        <mailto:[email protected]>] On Behalf Of Pavel Masloff
               Sent: Friday, December 02, 2011 2:52 PM
               To: [email protected]
        <mailto:[email protected]>; Dirk Zimoch; [email protected]
               Subject: [help] EPICS build no good
               Hello,
               This is my first attempt ever to build EPICS (and it's
        the first time I try to compile something really big, as a
        matter of fact).
               In accordance with the following instructions
        (http://www.aps.anl.gov/epics/base/win32.php) and
        recommendations by Dirk Zimoch (thanks!), I tried to build
        EPICS baseR3.14.12.1 on Windows 7 Starter using:
               * ActiveState Perl (ActivePerl-5.14.2.1402-MSWin32-x86)
               This is what I get :
               rc -l 0x409 -I. -I../O.Common -I.
        -I../../../sr
        -I../../../sr
               c/libCom/env -I../../../src/libCom/error
        -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
               m/gpHash -I../../../src/libCom/iocsh
        -I../../../src/libCom/logClient -I../../../src/libCom/macLib
               misc -I../../../src/libCom/osi
        -I../../../src/libCom/taskwd -I../../../src/libCom/timer
        -I../../../src/libCom/tsDefs -I.
               ./../../include/os/WIN32 -I../../../include        -fo
        Com.res ../Com.rc
               process_begin: CreateProcess(NULL, rc -l 0x409 -I.
        -I../../../src/l
        -I../..
        -I../../../src/l
        -I../../../src/l
        -I../../../include/os/WIN32 -I../../../include -fo Com.res
        ../Com.rc, ...) failed.
               make (e=2): No such file.
               mingw32-make[3]: *** [Com.res] Error 2
        `C:/epics/base/bin/win32-x86/src/libCom/O.win32-x86'
               mingw32-make[2]: *** [install.win32-x86] Error 2
        `C:/epics/base/bin/win32-x86/src/libCom'
        `C:/epics/base/bin/win32-x86/src'
        `C:/epics/base/bin/win32-x86'
               Why can it be so? The same thing using GnuWin32:
        -I../../../sr
        -I../../../sr
        Com.res ../Com.rc
        -I../../../src/l
        -I../..
        -I../../../src/l
        -I../../../src/l
               make: Leaving directory `C:/epics/base/bin/win32-x86'
               I set the PATH Environment Variable to:
         C:\Perl\site\bin;C:\Perl\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program
        Files\WIDCOMM\Bluetooth Software\;C:\Program
        Files\QuickTime\QTSystem\;C:\MinGW\bin;C:\GnuWin32\bin
               I don't know if there was a need to do so. Because I
        can see it's mentioned in the win32.bat file. Here's my
        win32.bat (in the ming32-make case):
               @ECHO OFF
               REM
               REM  Copyright (c) 2002 The University of Chicago, as
        Operator of Argonne
               REM      National Laboratory.
               REM  Copyright (c) 2002 The Regents of the University
        of California, as
               REM      Operator of Los Alamos National Laboratory.
               REM  EPICS BASE Versions 3.13.7
               REM  and higher are distributed subject to a Software
        License Agreement found
               REM  in file LICENSE that is included with this
        distribution.
               REM
               REM  Revision-Id:
        [email protected]
               REM
               REM  Site-specific EPICS environment settings
               REM
               REM  sites should modify these definitions
               REM ======================================================
               REM    ====== REQUIRED ENVIRONMENT VARIABLES FOLLOW ======
               REM   ---------------- WINDOWS ---------------------------
               REM ----- WIN95 -----
               REM set PATH=C:\WINDOWS;C:\WINDOWS\COMMAND
               REM ----- WINNT, WIN2000  -----
               REM set PATH=C:\WINNT;C:\WINNT\SYSTEM32
               REM ----- WINXP, Vista, Windows 7 -----
               set
        PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\SYSTEM32\Wbem
               REM   ---------------- make and perl ---------------------
               REM   --------------- ActiveState perl -------------------
               set PATH=C:\Perl\bin;%PATH%
               REM    --------------- mingw make ------------------------
               set PATH=C:\mingw\bin;%PATH%
               REM set PATH=C:\mingw-make82-3\bin;%PATH%
               REM   --------------- gnuwin32 make ----------------------
               REM set PATH=C:\gnuwin32\bin;%PATH%
               REM ---------------- cygwin tools ------------------------
               REM    (make & perl if above perl and make are REMs)
               REM    Dont use cygwin GNU make and Perl!
               REM    cygwin contains tk/tcl, vim, perl, and many unix
        tools
               REM    need grep from here NOT from cvs directory
               REM set PATH=%PATH%;.;..
               REM set PATH=%PATH%;c:\cygwin\bin
               REM   --------------- Visual c++ -------------------------
               REM    ------ Microsoft Visual Studio 2005 ------
               REM call "C:\Program files\Microsoft Visual Studio
        8\VC\vcvarsall.bat" x86_amd64
               REM set PATH=%PATH%;C:\Program Files\Microsoft
        SDKs\Windows\v6.0A\bin
               REM set INCLUDE=%INCLUDE%;C:\Program Files\Microsoft
        SDKs\Windows\v6.0A\include
               REM REM set LIBPATH=%LIBPATH%;C:\Program
        Files\Microsoft SDKs\Windows\v6.0A\lib
               REM set LIB=%LIB%;C:\Program Files\Microsoft
               REM    ------ Microsoft Visual Studio 2008 ------
        9.0\VC\bin\vcvars32.bat"
        9.0\VC\vcvarsall.bat" x86_amd64
               REM set    PATH=C:\Program Files\Microsoft
        SDKs\Windows\v7.0\bin;%PATH%
               REM set INCLUDE=C:\Program Files\Microsoft
        SDKs\Windows\v7.0\include;%INCLUDE%
               REM set LIBPATH=C:\Program Files\Microsoft
        SDKs\Windows\v7.0\lib;%LIBPATH%
               REM set     LIB=C:\Program Files\Microsoft
        SDKs\Windows\v7.0\lib;%LIB%
               REM    ----- Visual Studion 2010 -----
               REM --  windows-x64 ---
        10.0\VC\vcvarsall.bat" x64
               REM --  win32-x86 ---
        10.0\VC\vcvarsall.bat" x86
               REM --------------- EPICS --------------------------------
               REM set EPICS_HOST_ARCH=windows-x64
               set PATH=%PATH%;C:\epics\base\bin\%EPICS_HOST_ARCH%
               REM set
        PATH=%PATH%;G:\epics\extensions\bin\%EPICS_HOST_ARCH%
               REM ------- OPTIONAL ENVIRONMENT VARIABLES FOLLOW --------
               REM ----------------- remote CVS -------------------------
               REM set CVS_RSH=c:/cygwin/bin/ssh.exe
               REM set
        CVSROOT=:ext:[email protected]:/usr/local/epicsmgr/cvsroot
        <mailto:CVSROOT=:ext:[email protected]:/usr/local/epicsmgr/cvsroot>
               REM set HOME=c:/users/%USERNAME%
               REM set HOME=c:/users/jba
               REM ------------------- Bazaar ---------------------------
               REM set PATH=%PATH%;C:\Program files\Bazaar
               REM ----------------- GNU make flags ---------------------
               set MAKEFLAGS=-w
               REM -------------- vim (use cygwin vim ) -----------------
               REM HOME needed by vim to write .viminfo file.
               REM VIM needed by vim to find _vimrc file.
               REM set VIM=c:\cygwin
               REM --------------- Epics Channel Access -----------------
               REM    Modify and uncomment the following lines
               REM    to override the base/configure/CONFIG_ENV defaults
               REM set EPICS_CA_ADDR_LIST=n.n.n.n  n.n.n.n
               REM set EPICS_CA_AUTO_ADDR_LIST=YES
               REM set EPICS_CA_CONN_TMO=30.0
               REM set EPICS_CA_BEACON_PERIOD=15.0
               REM set EPICS_CA_REPEATER_PORT=5065
               REM set EPICS_CA_SERVER_PORT=5064
               REM set EPICS_TS_MIN_WEST=420
               REM --------------- JAVA ---------------------------------
               REM    Needed for java extensions
               REM set CLASSPATH=G:\epics\extensions\javalib
               REM set PATH=%PATH%;C:\j2sdk1.4.1_01\bin
               REM set
        CLASSPATH=%CLASSPATH%;C:\j2sdk1.4.1_01\lib\tools.jar
               REM --------------- Exceed -------------------------------
               REM    Needed for X11 extensions
               REM set EX_VER=7.10
               REM set EX_VER=12.00
               REM set EX_VER=14.00
               REM set PATH=%PATH%;C:\Exceed%EX_VER%\XDK\
        Files\Hummingbird\Connectivity\%EX_VER%\Exceed\
               Didn't change anything else. I think I missed
        something. What do you think I've missed?
               Thank you.
               Sincerely,
               Pavel Maslov, MSc
               R&D Institute for Electro-Physical Apparatus
               Mobile: +7 (951) 672 22 19
               Phone: +7 (812) 461 01 01
               Sincerely,
               Pavel Maslov, MSc
               Sincerely,
               Pavel Maslov, MSc
        Sincerely,
        Pavel Maslov, MSc
    Sincerely,
    Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
[help] EPICS build no good Pavel Masloff
RE: [help] EPICS build no good Mark Rivers
Re: [help] EPICS build no good Pavel Masloff
Prev: Re: [help] EPICS build no good Pavel Masloff
Next: Re: [help] EPICS build no good Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
