I assume you must have some form of internet connection as you are
emailing me. I would highly recommend installing gcc using yum if at
all possible. Also, this thread is starting to diverge from EPICS,
perhaps visiting RHEL or general linux forums would help with your
initial system setup.
Pavel Masloff wrote:
I have just noticed i don't have gcc installed. what is more i don't
have the internet connection to install it using yum. Are there any
other ways I can figure this out?
On Thu, Dec 8, 2011 at 2:42 PM, Pavel Masloff <[email protected]
<mailto:[email protected]>> wrote:
btw what's extensions?
On Thu, Dec 8, 2011 at 2:40 PM, Alan Greer
<[email protected]
Pavel,
I just noticed you are building for 64 bit so you don't want
EPICS_HOST_ARCH=linux-x86 you probably want
EPICS_HOST_ARCH=linux-x86_64
Sorry about that.
Alan Greer wrote:
OK, then to install base I would do something like the
following:
Setup a BASE location export
export BASE=/path/to/base
(Be warned I use "rm -rf" in places below as I have lifted
this from a script. This is a recursive forced remove and
could potentially delete many files).
The lines below basically unpack the source code into two
subdirectories base and extensions. I would set BASE to
something like
export BASE=~/applications/epics/R3-14-12-1
Then enter the following lines (or run from a script)
rm -rf $BASE/base
cp ./baseR3.14.12.1.tar.gz $BASE/baseR3.14.12.1.tar.gz
gunzip $BASE/baseR3.14.12.1.tar.gz
tar -xvf $BASE/baseR3.14.12.1.tar -C $BASE
rm -f $BASE/baseR3.14.12.1.tar
mv $BASE/base-3.14.12.1 $BASE/base
# Unpack the extensions sources
cp ./extensionsTop_20070703.tar.gz
$BASE/extensionsTop_20070703.tar.gz
gunzip $BASE/extensionsTop_20070703.tar.gz
tar -xvf $BASE/extensionsTop_20070703.tar -C $BASE
rm -f $BASE/extensionsTop_20070703.tar
# Update the EXTENSION_MSI link in the Makefile
sed "s/^EXTENSION_MSI.*/EXTENSION_MSI = msi1-5/"
$BASE/extensions/src/Makefile > Makefile.tmp
mv Makefile.tmp $BASE/extensions/src/Makefile
# Unpack the msi extension sources
cp ./msi1-5.tar.gz $BASE/extensions/src/msi1-5.tar.gz
gunzip $BASE/extensions/src/msi1-5.tar.gz
tar -xvf $BASE/extensions/src/msi1-5.tar -C
rm $BASE/extensions/src/msi1-5.tar
The files I used above are
msi1-5.tar.gz
Then...
# Export the required variables
export EPICS_BASE=$BASE/base
export EPICS_HOST_ARCH=linux-x86
export PATH=$PATH:$EPICS_BASE/bin/linux-x86
export PATH=$PATH:$EPICS_BASE/../extensions/bin/linux-x86
cd $BASE/base
make
make install
cd $BASE/extensions
make
make install
I'm sure there are better instructions in the many manuals
and tutorials that exist for EPICS.
Thanks, I'd figured this already :))
On Thu, Dec 8, 2011 at 1:19 PM, Alan Greer
<[email protected]
<mailto:[email protected]>>> wrote:
[ajg@osllx10 ~]$ export PATH=/temp/path
[ajg@osllx10 ~]$ echo $PATH
/temp/path
[ajg@osllx10 ~]$
[ajg@osllx10 ~]$ export EPICS_HOST_ARCH=linux-x86
[ajg@osllx10 ~]$ echo $EPICS_HOST_ARCH
linux-x86
[ajg@osllx10 ~]$
Hello everyone!
How can I set the environment variables (PATH and
EPICS_HOST_ARCH) in RHEL-5 64 bit?
I ran the EpicsHostArch.pl script (>> perl
EpicsHostArch.pl),
but this script only returns the variable,
doesn't set
anything. I check by running "dev" in the
command line.
And generally, what should one do to install
the epics base
from scratch on a linux machine?
Thanks.
Pavel.
-- Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
- [building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
- Re: [building EPICS in RHEL-5 64bit] environment variables Alan Greer
- Re: [building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
Re: Unbalanced conditional ? Paul Nord
<2011>
2025
<2011>
2025
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
