On Dec 12, 2011, at 7:51 AM, Pavel Masloff wrote: Hello, Nick! Dear colleagues!
Could you please explain how to use your TDS3000 support for my Tektronix 3054C (i have only the Ethernet interface)?
I am using the RHEL x86 operating system. I have successfully installed epics base (R3-14-12-1), extensions (1.7), sequencer (seq-2.1.3), asyn driver support (asyn4-18), tektronix tds3000 device support (tds3000-2.4) according to the manual. And they all seem to be working fine.
I think I have some problems with creating an application. I can't understand how to perform the following:
Using the software
In order to use the support in an application do the following:
Add the following to <top>/configure/RELEASE
TDS3000 = <full path to installation directory> ASYN = <full path to installation directory>
Add the following to the application Makefile.
<app>_LIBS_vxWorks += asyn <app>_LIBS_vxWorks += devTDS3000
There are two things wrong: 1) You are specifying libraries for vxWorks, but you are building an application for Linux. 2) Order of libraries is important. The asyn library must come after the devTDS3000 library.
Try changing the above two application Makefile lines to:
- Re: Tektronix 3000/5000 oscilloscopes Pavel Masloff
- [help] EPICS build no good Pavel Masloff
- Re: [help] EPICS build no good Andrew Johnson
- Re: [help] EPICS build no good Pavel Masloff
- Re: [help] EPICS build no good Dirk Zimoch
- Tektronix 3000/5000 oscilloscopes Eric Norum
Re: About the interface LabCA problem that Matlab can't read image data from areaDetector Till Straumann
<2011>
2025
RE: Tektronix 3000/5000 oscilloscopes Mark Rivers
<2011>
2025
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
