1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: pyepics3 Stripchart howto wanted
To: Peter Milne <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Mon, 12 Dec 2011 11:57:24 -0600
Hi Peter,
On Mon, Dec 12, 2011 at 4:25 AM, Peter Milne <[email protected]> wrote:
> Hi Matt
> Working with pyepics3, wanting to use the Stripchart, but not sure how.
> Attempting to run the Stripchart results in error trace.
> If I'm not running it correctly, please put me right, or if Stripchart isn't
> quite ready yet, no problem, can wait or beta test.
> The doc at http://cars9.uchicago.edu/software/python/pyepics3/
> looks excellent, and installation using easy_install mostly smooth.
> The wxmplot demo works well and looks very promising ..
> Thanks
> Peter
Yes, I can understand the problems you're seeing, as I've been sort of
actively working on wxmplot over the past month or so, and
subsequently broken and re-fixed the StripChart app a few times.  I
should warn you that I may continue altering wxmplot, but I'll try to
keep the Epics StripChart working!
I should probably post a version 0.98 of wxmplot, and a coincident
release of Epics Apps that will work with that version.   I'll try to
do that this week.  For now, the git repositories for both are working
together (though I made a fix today!), so cloning and building from
the github.com repositories (for wxmplot and epicsapps) might be the
best way to get StripChart working right now.
As far as I know, you're the only person besides me and my group using
the StripChart application, so if you have any suggestions, please let
me know.  If you're willing / able to provide fixes to code, that
would be wonderful.
Cheers,
--Matt Newville <newville at cars.uchicago.edu> 630-252-0431
pyepics3 Stripchart howto wanted Peter Milne
Prev: Re: Tektronix 3000/5000 oscilloscopes Pavel Masloff
Next: RE: Tektronix 3000/5000 oscilloscopes Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: pyepics3 Stripchart howto wanted Peter Milne
Next: EPICS Base 3.14.12.2 Released Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
